Shaping / PPP Multilink
GRANT3779
I have a few GRE/IPSEC VPN tunnels configured going over a WAN PPP Multilink.
Can I apply shaping in this setup? Where would the service-policy be attached to? The Multilink as a whole or on the actual Tunnel Interfaces?
Joseph W. Doherty
Depends which you want to shape.  I recall a few devices support shaping on both.
If you wondering why you might shape both, you would shape a tunnel for "far side" bandwidth.  You would shape the multilink for a near side CIR.
Not sure if what I am attempting is possible, or a better way of doing things -
I have the following - I am looking to shape the link as a whole to 4Mbps, and also within that shape certain traffic type to only 256k. When I apply this below to the Multilink the router just reboots after a few second with the following error upon reload.
System returned to ROM by error - a Software forced crash
IOS  - c2900-universalk9-mz.SPA.150-1.M3.bin"
class-map match-any CM_RIG_SHAPE
match access-group name ACL_MAPI_1
match access-group name ACL_MAPI_2
policy-map PM_RIG_SHAPE
class CM_RIG_SHAPE
shape average 256000
policy-map PM_Multilink
class class-default
shape average 4000000
service-policy PM_RIG_SHAPE
interface multilink 1
service-policy output PM_Multilink
The fact the router accepts the config gives some hope, but I'm not surprised that a policy like this also crashes the device.
If you have a support contract, you might open a TAC case and/or just try newer IOS version(s).
