SSH2_UNEXPECTED
Hi.
Could someone help me understand why logs that are occurring in the Cisco 2911 router?
003865: Jul 18 14:26:25.196 GMT-3: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection
003866: Jul 18 14:26:30.644 GMT-3: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection
003867: Jul 18 14:27:00.065 GMT-3: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection
003868: Jul 18 14:27:23.766 GMT-3: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection
003869: Jul 18 14:27:26.018 GMT-3: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection
Thank,
johnd2310
Level 8
Level 8
What ssh client are you using?
John
**Please rate posts you find helpful**
 What is the command I check the ssh cliente?
#show ssh
Connection Version Mode Encryption  Hmac         State                 Username
514        2.0      -       -          -         Version checked       -
1          2.0     IN   aes256-cbc  hmac-sha1    Session started       manoel
1          2.0     OUT  aes256-cbc  hmac-sha1    Session started       manoel
%No SSHv1 server connections running.
Can you post the output of show ip ssh
That will show what versions of ssh you have enabled. My guess is that you have enabled version 2 and not 1. If someone attempted access with version 1 when it is not enabled I believe that it would generate the type of message that you ask about.
Rick
Rick
