SSL Termination on Cisco ISR Router
tech_trac
Is it possible to terminate HTTPS traffic on the ISR Router. That is, SSL certificate is loaded on the router and when user accessess https://www.abc.com the router enters into three-way SSL handshake with the user client and then forwards the traffic to the server farms. (Similar to SSL offloading on Cisco ACE appliances).
Thanks.
Giuseppe Larosa
if you haven't already read it, the following is the VPN SSL config chapter in 12.4 mainline
http://www.cisco.com/en/US/docs/ios/sec_secure_connectivity/configuration/guide/sec_ssl_vpn_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
