SSL VPN not working
jopetik09
Hi All,
I have ASA 5505 with outside interface IP 206.206.206.5 I configured the SSL vpn on this but still i am getting page can not be displaed when opening https://206.206.206.5 from broadband.
Below is the related configuration in ASA.
Could someone look the configuration and suggest me where i went wrong and what needs to be done in order to able to connect SSL vpn.
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
vpn-tunnel-protocol IPSec l2tp-ipsec
webvpn
  functions url-entry file-access file-entry file-browsing
tunnel-group DefaultWEBVPNGroup general-attributes
default-group-policy GroupPolicy1
tunnel-group DefaultWEBVPNGroup webvpn-attributes
nbns-server 10.10.10.11 timeout 2 retry 2
policy-map type inspect http Http_inspect_policy
parameters
  protocol-violation action drop-connection
class BlockDomainClass
  reset
policy-map global-policy
class global-class
  inspect dns
  inspect esmtp
  inspect ftp
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect snmp
  inspect sqlnet
  inspect tftp
  inspect xdmcp
  inspect icmp
policy-map inside-policy
class HTTPTrafic
service-policy global-policy global
webvpn
enable outside
url-list nuk001 "abc002" cifs://10.10.10.1 1
Your help is really appreciated.
Jopeti.
Richard Burts
Jopeti
I believe that the problem is that you have not enabled SSL VPN. Here are the tunneling protocols that you have enabled:
I suggest that you add to this the protocol svc
Give it a try and let us know if it helps.
Rick
Rick
Hi Rick,
Thanks for your response and support.
I have enabled the webvpn on outside but still it is not working. Please find the below complete running config of my ASA5505.
And one morething when I tried to enable webvpn outside on another ASA (on which already I have enabled cisco easyvpn) it is giving me following error. Could you please let me know what is the alternative way in this scenario.
(config-webvpn)# enable outside
ERROR: This configuration cannot be modified with Cisco Easy VPN Remote enabled.
ASA# sh run
: Saved
ASA Version 7.2(4)
terminal width 136
hostname ASA
names
name 10.10.0.0 bejing
name 192.168.200.0 UK
interface Vlan1
nameif inside
security-level 100
ip address 10.50.1.10 255.255.0.0 standby 10.50.1.11
interface Vlan2
nameif outside
security-level 0
ip address 206.206.206.206 255.255.255.248 standby 206.206.206.207
interface Vlan100
description LAN Failover Interface
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
switchport access vlan 100
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
object-group network VPN-access
network-object 10.120.0.0 255.255.0.0
object-group network DM_INLINE_NETWORK_1
network-object 10.50.0.0 255.255.0.0
network-object GBK 255.255.0.0
access-list outside_access_in extended deny icmp any 206.206.206.211 255.255.255.248
access-list outside_access_out extended permit ip any any
access-list inside_access_in extended permit ip any any
access-list GBVPN_splitTunnelAcl standard permit 10.20.0.0 255.255.0.0
access-list inside_nat0_outbound extended permit ip object-group VPN-access 10.50.100.0 255.255.255.224
access-list inside_mpc extended permit tcp any any eq www inactive
access-list inside_nat_outbound extended permit ip object-group DM_INLINE_NETWORK_1 any
access-list inside extended permit tcp 10.50.0.0 255.255.0.0 host 217.217.285.256 eq https
no pager
logging enable
logging timestamp
logging trap informational
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool GBVPNpool 10.50.100.1-10.50.100.20 mask 255.255.255.224
ip local pool SSL-VPN 192.168.100.200-192.168.100.250 mask 255.255.255.0
icmp deny host 206.206.206.206 outside
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list no_nat
nat (inside) 1 access-list inside_nat_outbound
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
access-group outside_access_out out interface outside
route inside 10.0.0.0 255.0.0.0 10.50.1.1 1
route outside 0.0.0.0 0.0.0.0 206.206.206.206 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
service resetoutside
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto ca trustpoint localtrust
enrollment self
fqdn ASA.dg.local
subject-name CN= ASA.dg.local
keypair ***************
crl configure
crypto ca certificate chain localtrust
certificate 31
    308201fe 30820167 a0030201 02020131 300d0609 2a864886 f70d0101 04050030
    45311e30 1c060355 04031315 20437578 68617665 6e415341 2e72672e 6c6f6361
    6c312330 2106092a 864886f7 0d010902 16144375 78686176 656e4153 412e7267
    2e6c6f63 616c301e 170d3131 30363230 30363539 35325a17 0d323130 36313730
    36353935 325a3045 311e301c 06035504 03131520 43757868 6176656e 4153412e
    72672e6c 6f63616c 31233021 06092a86 4886f70d 01090216 14437578 68617665
    6e415341 2e72672e 6c6f6361 6c30819f 300d0609 2a864886 f70d0101 01050003
    818d0030 81890281 8100c0aa e5b025a0 59180e10 8f9c8d77 5d6bb492 0e8cec2c
    8111f881 57645033 42dd7d86 07afc7ca 368a0ce2 8db1409f 3716eab5 e6b4ac2f
    26ba29a1 ff31f8b6 6b61a5f3 37f2478e 4916d1eb d8d8ac31 75bf4855 0afc717c
    0956561d 4fc44dd4 5f24a885 d231de61 8537976b abed9c18 574d864d f3ed14af
    8cbd7388 d04c6647 1d0d0203 01000130 0d06092a 864886f7 0d010104 05000381
    8100ab1e 39926604 72cf34cb ca0dbcfb 1a056b30 4b33f483 0c541481 502e6cba
    691e83d9 71a562f7 e1a0b19c ad95cb80 61c71c4a 0fe3e82c 3a2465ae 9777c64f
    3cec439f 874ef005 c480f108 33dc555f 014db4d6 b2ac32ad 2afe0c93 4aa95135
    4ec4c480 336d78a7 27ab4038 d0488748 02a231dc d65aac61 e0b98945 1f3e9926 7c62
  quit
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
ssl trust-point localtrust outside
webvpn
enable outside
svc enable
group-policy DfltGrpPolicy attributes
banner none
wins-server value 10.50.2.11
dns-server value 10.50.2.31
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol webvpn
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
split-tunnel-network-list none
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools value SSL-VPN
smartcard-removal-disconnect enable
client-firewall none
client-access-rule none
webvpn
  functions url-entry
  html-content-filter none
  homepage none
  keep-alive-ignore 4
  http-comp gzip
  filter none
  url-list none
  customization value DfltCustomization
  port-forward none
  port-forward-name value Application Access
  sso-server none
  deny-message value Login was successful, but because certain criteria have not been met or due to some
specific group policy, you do not have permission to use any of the VPN features. Contact your IT
administrator for more information
  svc none
  svc keep-installer installed
  svc keepalive none
  svc rekey time none
  svc rekey method none
  svc dpd-interval client none
  svc dpd-interval gateway none
  svc compression deflate
group-policy GBVPN internal
group-policy GBVPN attributes
dns-server value 10.50.2.11
split-tunnel-policy tunnelspecified
split-tunnel-network-list value GBVPN_splitTunnelAcl
default-domain value dg.local
group-policy Operations internal
group-policy Operations attributes
banner value Tech Op Remote Access
banner value Unauthorized access prohibited
webvpn
  homepage none
  svc none
username dbgij password ************* encrypted
tunnel-group GBVPN type ipsec-ra
tunnel-group GBVPN general-attributes
address-pool (inside) GBVPNpool
address-pool GBVPNpool
authentication-server-group ********* LOCAL
default-group-policy GBVPN
tunnel-group GBVPN ipsec-attributes
pre-shared-key **************
tunnel-group RA_SSL type webvpn
tunnel-group RA_SSL webvpn-attributes
group-alias RA_SSL enable
group-url https://206.206.206.206/RA_SSL enable
class-map global-class
match default-inspection-traffic
class-map type regex match-any DomainBlockList
match regex Youtube
class-map type inspect http match-all BlockDomainClass
match request header host regex class DomainBlockList
class-map HTTPTrafic
match access-list inside_mpc
parameters
  reset
class global-class
  inspect dns
  inspect esmtp
  inspect ftp
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect snmp
  inspect sqlnet
  inspect tftp
  inspect xdmcp
  inspect icmp
class HTTPTrafic
service-policy inside-policy interface inside
prompt hostname context
Cryptochecksum:ea5c8c13f6c68f0b361367f81de3bbaa
: end
Jopeti.
