Stac compression:Easy question on total bytes
news2010a
Level 3
Level 3
Hi, can you clarify this?
Based on the router output below, imagine I want to find out
the total amount of data to be transmitted before applying
compression.
Initially I thought that it would be value 130,000
by looking at the line "uncompressed bytes xmt/rcv".
It seems that is not the case though.
Can you please clarify how I should look into this ?
routerA#show compress
serial 0/1
uncompressed bytes xmt/rcv 130000/130500
1 min avg ration xmt/rcv 0.789/0.837
5 min avg ration xmt/rcv 0.789/0.837
10 min avg ratio xmt/rcv 0.789/0.837
no bufs xmt 0 no bufs rcv 0
restarts 0
Additional Stacker Stats
Transmit bytes: Uncompressed=50000 Compressed=50000
Received bytes: Compressed=60000 Uncompressed = 0
carenas123
Level 5
Level 5
Total amount of data to be transmitted before compression is 135000 which is uncompressed bytes xmt 130000 and Additional Stacker Stats Transmit bytes: Uncompressed=50000.Refer URL
http://www.cisco.com/en/US/tech/tk713/tk802/technologies_tech_note09186a008035b8c5.shtml#topic1c
