870 router command
scripttron75
I need help configuring a 870 series router. how do i configure a user name what are the commands?? i need to be able to login with a user name when i am configuring the router from a pc!!
5 Replies 5
amit-singh
Level 8
Level 8
Conf t
username xxxx password yyyy priviledge 15
line vty 0 4
login local
line vty 5 15
login local
HTH, Please rate if it does.
-amit singh
Hi thanks for your help. that did not work!!
when i boot up it comes to the router hostname then i hit enable and it only asks for a password. I need it to ask for a username and password??
Changed the first command a little bit.
Conf t
username xxxx priviledge 15 password yyyy
enable secret aaaa
service password-encryption
Line console 0
login local
line vty 0 4
login local
HTH,
-amit singh
do i have to input these commands
Line console 0
login local
line vty 0 4
login local
Yes you have to enter those commands so the router will use the local username and password configured on the router.
