Standby Sup Engine Does not boot
ajkhader123
I am trying to configure 7609Router, when i booted the device supengine on slot 5 booted as Active but on slot 6 supengine did not boot, i am getting an
Error:loadprog: bad file magic number: 0x0
Please help me on this issue,
vishwancc
Level 3
Level 3
It seems the flash is corrupted on the Standby Sup.
Could you console into the Standby and check if it is in rommon.
Check for the files in the directory ,if nothing is there i will suggest to copy the new image which is running on the active to standby.
Chao
Vishwa
