Starlink on Cisco C921-4P
Nicolas74
Hi all,
Need some help to setup correctly my c921-4P to use Starlink as internet accès connected on my Wan Port.
I can't acces to Internet, Starling is on Bypass mode.
My conf. is:
interface GigabitEthernet0
switchport access vlan 3
switchport trunk native vlan 3
switchport mode trunk
no ip address
interface GigabitEthernet1
switchport access vlan 4
switchport trunk native vlan 4
no ip address
interface GigabitEthernet2
switchport access vlan 5
switchport trunk native vlan 5
no ip address
interface GigabitEthernet3
switchport access vlan 6
switchport trunk native vlan 6
no ip address
interface GigabitEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Vlan3
ip address 192.168.30.3 255.255.255.0
ip nat inside
interface Vlan4
ip address 192.168.40.3 255.255.255.0
ip nat inside
interface Vlan5
ip address 192.168.50.3 255.255.255.0
ip nat inside
interface Vlan6
ip address 192.168.60.3 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list SAEM interface GigabitEthernet4 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet4 dhcp
ip access-list standard SAEM
permit 192.168.50.0 0.0.0.255
control-plane
banner motd ^C****ACCES AU ROUTEUR STARLINK***^C
line con 0
line vty 0 4
login local
transport input ssh
scheduler allocate 20000 1000
end
Thanks a lot for your help
Nico
27 Replies 27
Unfortunately i already done this change and no change...
so just to recap: the router gets a public IP address, and from the router, you can ping 8.8.8.8 ?
Also, what if you configure interface GigabitEthernet5 as the uplink port ?
Yes i ping 8.8.8.8 from the router same if i configure interface GigabitEthernet5 as uplink port.
I disable router dns resolution to try: "no ip domain lookup" => no result.
Starlink apparently uses a default MTU of 1500. Maybe the one configured for your link is different. Can you send an extended ping to check if 1500 actually gets a response ?
Done and no result.
I'm going to ask Cisco's support. I will post back the solution if they find ;).
smignacc@cisco.com
Hi Nicolas,
Did you open a TAC case for this specific, I would be curious to see how it was resolved if it's the case.
Sincerely,
Hi Smignac,
Have done differents test with Cisco Enginer and no good result... they thinks c921p have a problem and preconise to replace it.
Thx for your help
pieterh
one more test you can do
- remove the Cisco router and connect your computer directly to the starlink modem
- check what network settings you receive from DHCP (gateway, DNS)
- check internet connectivity
if this also fails then the problem may not be in the Cisco routers config
THanks for reaching out. Confirm that everything is working perfectly going straight to my laptop when Starlink in Bypass mode.
and what are the DHCP network settings you received from your provider ?
or did you use manual configuration
Hi Pieterh,
Already tests all you recommended but the internet connection is ok, tested directly and with an other router and work properly.
ausjustin
Hi Nicolas
I have same issue and how did you resolve the issues?
thanks
Justin
smignacc@cisco.com
No, workaround was to use Starlink router and extend L2 to my user network, keeping at the same time the Starlink DHCP server. Really not ideal but I haven't found any other options. No support from Starlink whatsoever.
