Static & Dynamic NAT and Outside connection in Cisco 2811
megaservicescl
Hello Cisco gurus, I think it's time to ask for help!
This is the scenario:
- Cisco router model 2811 with firmware c2800nm-advsecurityk9-mz.151-4.M10 and 2 interfaces f0/0 and f0/1
- 5 public IP from 200.xxx.xxx.234 to 200.xxx.xxx.238
- 2 web, mail, ftp and dns servers (SRV1 and SRV2)
I want to use 3 of this 5 IP's:
- LAN from 192.168.1.30 to 192.168.1.254 -> 200.xxx.xxx.236
- SRV1 in 192.168.1.10 -> 200.xxx.xxx.237
- SRV2 in 192.168.1.20 -> 200.xxx.xxx.238
After 3 days of reading and testing configurations, I can connect to the internet from the LAN (no problems here), but I can't see the server's from outside the local network.
I would be very grateful if someone can help me with this problem!
Here is my running configuration:
ip dhcp excluded-address 192.168.1.1 192.168.1.30
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 200.xx.xxx.227 200.xx.xx.90
redundancy
interface FastEthernet0/0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
ip address 200.xxx.xxx.236 255.255.255.248
ip nat outside
duplex auto
speed auto
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source static 192.168.1.10 200.xxx.xxx.237
ip nat inside source static 192.168.1.20 200.xxx.xxx.238
ip route 0.0.0.0 0.0.0.0 200.xxx.xxx.233
access-list 1 permit 192.168.1.0 0.0.0.255
Philip D'Ath
The configuration is correct.
Can 192.168.1.10 and 192.168.1.20 access the Internet ok (verifying their routing configuration)?
Is a local firewall, such as Windows Firewall, configured to allow the traffic?
Can you access whatever the service is directly on the servers to prove those services are working?
Hello Philip,
Thank you for your reply.
Well, after various tests, I realized that I can connect to the server services from computers not connected in the same IP range (200.xxx.xxx.234 to 200.xxx.xxx.238).
My solution was to use route-maps in the static NAT.
Now I can navigate the server's web pages, ftp, etc. using domain's/hostname, but yet I can't connect to the server's using the outside IP.
ssh://domain.ltd:22 work
ssh://200.xxx.xxx.238:22 don't work
Any help?
ip nat inside source list LAN_ACL interface FastEthernet0/1 overload
ip nat inside source static 192.168.1.10 200.xxx.xxx.237 route-map SRV1 extendable
ip nat inside source static 192.168.1.20 200.xxx.xxx.238 route-map SRV2 extendable
ip access-list extended LAN_ACL
deny ip host 192.168.1.10 any
deny ip host 192.168.1.20 any
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended SRV1_ACL
permit ip host 192.168.1.10 any
route-map SRV1 permit 10
match ip address SRV1_ACL
ip access-list extended SRV2_ACL
permit ip host 192.168.1.20 any
route-map SRV2 permit 10
match ip address SRV2_ACL
