Static NAT an entire Class C
dennylester
We purchased a company that happens to have the same addressing as another one of our sites. Rather than renumbering one of the locations, we want to setup NAT translations on their router.
Can I static NAT their entire Class to to another one with one command, or do I need to enter a bunch of individual static nat commands?
I hope that makes sense.
Denny
rais
Level 7
Level 7
The ip nat command has a pool option and would translate the whole subnet to new addresses.
I am familiar with the pool but it was my impression the pool was random. I would like an exact one for one with the last octet being the same.
For example
192.168.1.1 ==> 192.168.100.1
192.168.1.2 ==> 192.168.100.2
etc
etc
Does this pool follow this order, or would it be possible for
192.168.1.23 ==> 192.168.100.1
Denny
denny you will have some keyword like "match-host" that will solve your issue.
for more information:http://www.cisco.com/en/US/products/ps6350/products_command_reference_chapter09186a00804461e8.html#wp1178676
regards
Devang
you can also try
ip nat source static network 192.168.1.0 192.168.100.0 255.255.255.0
command
