Static NAT changes source port.
ranga2002
Hi team,
I have a requirement, where I have to allow communication between two devices in two remote networks, which is going through a NAT device keeping original source and destination ports.
Site A ---------------  NAT Firewall------------------The Internet---------------------Site B
S:10.131.1.2                S:10.131.5.2        D:10.101.1.2
UDP port 2000         UDP Port 10381        UDP port 2000
Original source IP is source NAT'd to 10.131.5.2. Then it communicates with the destination IP 10.101.1.2.
Once we configured a static source NAT, we observed the NAT device keep changing the source port(UDP 2000) to a random number (in this case UDP 10381), which violates the customer requirement. However, the destination port remains the same.
Is there a way I can keep the source port unchanged as UDP 2000 and the destination port as UDP 2000?
Thanks in advance.
as far as I recall, in JunOS, port randomization is enabled by default. Try and disable that:
set security nat source port-randomization disable
5 Replies 5
what is the 'NAT device', is that an ASA firewall ?
It is a Juniper (JunOS) firewall.
Thanks Georg. I will try this out. My gut feeling is this should resolve it.
balaji.bandi
Not tried  myself - try "no-payload"
 example : (change this to UDP as per the requirement)
ip nat inside source static tcp x.x.x.x 80 y.y.y.y 80 [no-payload]
BB
