Static Nat issue on Router: router not accepting more then 2 static NAT commands
hashimwajid1
Level 3
Level 3
i am doing Natting  on Cisco router 4321.
 for LAN users i am doing dynamic Nat.
 ip nat inside source list INTERNET interface Dialer1 overload
 ip access-list extended INTERNET
   permit ip any any
customer also want to access CCTV from outside.. now the problem starts...when i am doing static NAT port forwarding for access from outside.. i want to open 4 ports for 1 CCTV as per customer requirement.. so i created static NAT entries
ip nat inside source static tcp 192.168.1.20 8080 interface Dialer1 10443
ip nat inside source static tcp 192.168.1.20 554 interface Dialer1 10443
ip nat inside source static udp 192.168.1.20 37778 interface Dialer1 10443
ip nat inside source static tcp 192.168.1.20 37777 interface Dialer1 10443
problem is router accepting only 2 static commands. when i enter 3rd and 4th static commands, these new command over right the previous 2 commands.. so i cannot add more then 2 static NAT entries...
1- why i cannot add more static NAT entries.. i am using IPbase license on router ?
 2-is there any limitation for static Nat entries ?
    router has ADSL connection
3- is there any other way to add static NAT port forwarding for 4 ports in single command ?
Running Config
ADSL-Router#sh run
Building configuration...
Current configuration : 2258 bytes
! Last configuration change at 17:22:06 UTC Sun Aug 6 2017 by admin
version 15.4
no platform punt-keepalive disable-kernel-core
hostname ADSL-Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$nBpV$rgxALNQ8Wn6Enlx8snLHg0
no aaa new-model
ip name-server X.X.X.X
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool LPG
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server X.X.X.X
subscriber templating
license udi pid ISR4321/K9 sn FDO2021134D
username admin password 0 Cisco
redundancy
mode none
interface GigabitEthernet0/0/0
description LAN
ip nat inside
negotiation auto
interface GigabitEthernet0/0/1
description WAN
no ip address
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname bplpg
ppp chap password 0 d1acmmy5
ppp pap sent-username bplpg password 0 d1acmmy5
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
no ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended CCTV
permit ip any 192.168.1.0 0.0.0.255
permit ip any any
access-list 100 permit ip any any
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
transport input all
end
Hello
Nat doesn't like an acl with any any, you need to specify the subnet that you wish to be natted
permit ip any any
permit ip 192.168.1.0 0.0.0.255 any
also try this:
ip nat inside source static tcp 192.168.1.20 8080 interface Dialer1 8080
ip nat inside source static tcp 192.168.1.20 554 interface Dialer1 554
ip nat inside source static udp 192.168.1.20 37778 interface Dialer1 37778
ip nat inside source static tcp 192.168.1.20 37777 interface Dialer1 37777
res
paul
Kind Regards
Paul
10 Replies 10
Hello
permit ip any any
also try this:
res
paul
Kind Regards
Paul
Hi Paul
1-NAT is working fine for LAN users with that ACL (although i will change the ACL for more specific)
2-Customer want to map the single server IP for 4 different ports with single outside port
    is is possible to map single outside port 10443  for single inside server IP 192.168.1.20 but 4 different inside ports ?
3- Router is not accepting more then 2 static entries, is it normal behavior ?
thanks for your feed back
If you map the same port to 4 different inside ports how will the router know which port you want to send it to on the server ?
If the source IPs for each port were different then it could probably be done but I suspect they aren't.
Jon
HI Jhon,
customer was using D-LINK router previously. and they were accessing CCTV from outside via dyndns
so when they click like https://0086760877546e10.hecxnyyur-ddns.com:10443/ they can access there server from outside by clicking this link..
now customer installed the Cisco Router and he gave me that list to create the port forwarding according to given below list.
 tcp 192.168.1.20 8080 >>>interface dialer1 10443
 tcp 192.168.1.20 554 >>>interface dialer1 10443
 tcp 192.168.1.20 37777 >>>interface dialer1 10443
 udp 192.168.1.20 37778 >>>interface dialer1 10443
if this is wrong then what should be the right configuration in order to access the CCTV via above given link ?
thanks for your comments
To be honest I have no idea because I have not used that application so can't say.
But as I said I can't see how it would work as is because the router would have no way of knowing which real port to send it to.
Jon
Hello
I think you should check with the client regards their requirements I don't think a single url would work.
The below port forwarding should however but it wont be on the same url
res
Paul
Kind Regards
Paul
Rob Cluett
It appears the switch is bright enough to know that you're doing something that shouldn't be done...  Using that same destination interface and port.  My switch doesn't like it either. I get one entry after typing all four commands in.
Hello Rob
whilst you have the rtr open can you test the static nat port to port as I posted previously the rtr should take it
Just for validation
res
paul
Kind Regards
Paul
Entered without issue.
Hello
Much appreciated
res
Paul
Kind Regards
Paul
