Static NAT not working
chris.fletcher1
I'm having a hard time doing some simple port forwarding for port 80 and 25. I've tried using both the public IP address and the interface. I've tried with and without an ACL. My config is below. Please tell me I'm missing something obvious here.
From the router I can telnet to both port 80 and 25 using the local addresses.
interface GigabitEthernet0/0
 description WAN
 no ip address
 ip access-group WAN in
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
 description LAN
 ip address 192.168.1.7 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Dialer1
 description Logical ADSL Interface
 ip address negotiated
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 dialer-group 1
 ppp chap hostname *********
 ppp chap password 0 *********
 ppp ipcp route default
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.4 25 interface Dialer1 25
ip nat inside source static tcp 192.168.1.16 80 63.224.141.28 80 extendable
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard LAN
 permit 192.168.1.0 0.0.0.255
ip access-list extended WAN
 permit ip any any
access-list 10 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
 login local
 transport input all
line vty 5 15
 login local
 transport input all
scheduler allocate 20000 1000
end
Duplicate post -
https://supportforums.cisco.com/discussion/12712311/help-static-nat-isnt-working
Kind Regards
Paul
