static nat on subinterfaces
marcel3007
Community Member
Hello from Berlin 🙂
following scenario:
Now, i want to access the www server from public and insert a static ip nat inside arguemnt but it doesnt work. On the ww server (my pc in this example) i have a internet connection. All works fine, only the nat / pat translation doesent works.
Here is my config of my Router:
configure terminal
hostname Rtr_Chab
no ip http
no ip source-route
line con 0
 logging synchronous
exit
username vpn01 password vpn01
username vpn02 password vpn02
enable password xxx
interface loopback 0
 description Testinterface
 ip add 172.16.99.1 255.255.255.255
exit
line vty 0 15
 login local
 password xxx
exit
interface fa0/0
 description WAN Interface
 ip address dhcp
 ip nat outside
 no shutdown
exit
interface fa0/1
 description LAN Interface
 no shutdown
exit
interface fa0/1.10
 description VLAN 10 K-Netz
 encapsulation dot1q 10 native
 ip address 192.168.9.200 255.255.255.0
 ip nat inside
 no shutdown
exit
interface fa0/1.20
 description VLAN 20 Charlottenburg-Netz
 encapsulation dot1q 20
 ip address 172.16.20.1 255.255.255.0
 ip nat inside
 no shutdown
exit
interface fa0/1.30
 description VLAN 30 Charlottenburg-Admin-Netz
 encapsulation dot1q 30
 ip address 172.16.30.1 255.255.255.0
 ip nat inside
 no shutdown
exit
interface fa0/1.40
 description VLAN 40 VPN-Netz
 encapsulation dot1q 40
 ip address 172.16.40.1 255.255.255.0
 ip nat inside
 no shutdown
exit
ip dhcp excluded-address 172.16.20.1 172.16.20.100
ip dhcp pool Pool_Charlottenburg-Netz
 network 172.16.20.0 255.255.255.0
 default-router 172.16.20.1
 import all
exit
ip dhcp pool Pool_Charlottenburg-Admin-Netz
 network 172.16.30.0 255.255.255.0
 default-router 172.16.30.1
 import all
exit
ip dhcp pool Pool_VPN-Netz
 network 172.16.40.0 255.255.255.0
 default-router 172.16.40.1
 import all
exit
no access-list 1
access-list 1 permit 192.168.9.0 0.0.0.255
access-list 1 permit 172.16.20.0 0.0.0.255
access-list 1 permit 172.16.30.0 0.0.0.255
access-list 1 permit 172.16.40.0 0.0.0.255
access-list 1 permit 172.16.99.1 0.0.0.0
ip nat inside source list 1 interface fa0/0 overload
ip nat inside source static tcp 172.16.20.101 80 interface fa0/0 80
vpdn enable
vpdn-group 1
 accept-dialin
  protocol pptp
  virtual-template 1
exit
interface Virtual-Template1
 description PPTP Einwahl Interface fuer VPN Zugang
 ip unnumbered fa0/1.40
 no keepalive
 no cdp enable
 peer default ip address dhcp-pool Pool_VPN-Netz
 ppp encrypt mppe 128 required
 ppp authentication ms-chap-v2
exit
end
and my configuration of the switch:
configure terminal
default interface range fastEthernet0/1 - 24
hostname SW_Chab
line con 0
 logging synchronous
 exit
interface vlan 30
 ip address 172.16.30.2 255.255.255.0
 no shutdown
exit
ip default-gateway 172.16.30.1
interface fa0/1
 description Service-PC Admin-Netz
 switchport mode access
 switchport access vlan 30
 spanning-tree portfast
 spanning-tree bpduguard enable
 no shutdown
exit
interface fa0/2
 description Service-PC (temp) Admin-Netz
 no shutdown
exit
interface fa0/9
 description Techniker-PC Chab
 switchport access vlan 20
 no shutdown
exit
interface fa0/10
 description Drucker Chab
 no shutdown
exit
interface fa0/22
 description AccessPoint Chab
 switchport mode trunk
 switchport trunk native vlan 20
 no shutdown
exit
interface fa0/23
 description KAP-Netz
 switchport trunk native vlan 10
 no shutdown
exit
interface fa0/24
 description Router
 no shutdown
exit
Hopefully you can help me.
Thanks!
Marcel
Hello
"Remove the old statements before applying the below"
int xx
no ip nat inside
no ip nat outside
ip nat enable
exit
no ip nat inside source list 1 interface fa0/0 overload
no ip nat inside source static tcp 172.16.20.101 80 interface fa0/0 80
ip nat source list 1 interface fa0/0 overload
ip nat source static tcp 172.16.20.101 80 interface fa0/0 80 extendable ( if applicable)
res
Paul
Kind Regards
Paul
6 Replies 6
Hello
Can you try adding the extenable keyword to the end of the static mapping
ip nat inside source static tcp 172.16.20.101 80 interface fa0/0 80 extenable
res
Paul
Kind Regards
Paul
Hi Paul,
i doesent have the extenable command in my ios version. I have the version c1841-adventerprisek9-mz.151-4.M1.bin installed. Should i try with another version?
Marcel
hello
Yes you can do, however befroe you do that try using NVI Nat ( domainless nat) its nat order is different then domain nat as it performs lookups before and after translation
Remove the old statments before applying the below:
int xx
ip nat enable
extenable
res
Paul
Kind Regards
Paul
Sorry, dont know if i understand you right.
I have disable now the ip virtual-reassembly and downgrade to ios 12.4.
I have try to apply the statements you post but i havent the extenable command.
Here is my complete show run, hope you can find something (the ip route statements are dynamically because the ip nat statements):
Current configuration : 3170 bytes
version 12.4
hostname Rtr_Chab
boot-start-marker
boot system flash:/c1841-adventerprisek9-mz.124-25f.bin
boot-end-marker
no aaa new-model
no ip source-route
ip cef
no ip dhcp use vrf connected
   import all
   import all
   import all
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
 accept-dialin
  protocol pptp
  virtual-template 1
username vpn01 password 0 vpn01
username vpn02 password 0 vpn02
controller DSL 0/0/0
 line-term cpe
interface Loopback0
 ip address 172.16.99.1 255.255.255.255
interface FastEthernet0/0
 ip address dhcp
 ip nat outside
 ip nat enable
 no ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 ip nat enable
 duplex auto
 speed auto
interface FastEthernet0/1.10
 description VLAN 10 KAP-Netz
 encapsulation dot1Q 10 native
 ip nat inside
 ip nat enable
interface FastEthernet0/1.20
 encapsulation dot1Q 20
 ip nat inside
 ip nat enable
interface FastEthernet0/1.30
 encapsulation dot1Q 30
 ip nat inside
 ip nat enable
interface FastEthernet0/1.40
 encapsulation dot1Q 40
 ip nat inside
 ip nat enable
 ip unnumbered FastEthernet0/1.40
 no keepalive
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 91.64.82.254 254
ip route 0.0.0.0 0.0.0.0 91.64.191.254 254
ip route 0.0.0.0 0.0.0.0 91.64.81.254 254
ip route 0.0.0.0 0.0.0.0 24.134.39.254 254
no ip http server
no ip http secure-server
ip nat source static tcp 172.16.20.101 80 interface FastEthernet0/0 80
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit any
control-plane
end
Hello
int xx
no ip nat inside
no ip nat outside
ip nat enable
exit
res
Paul
Kind Regards
Paul
Hi Paul,
thank you very much! That was the solution for my problem. For all others, here is my final config:
exit
interface fa0/0
 ip address dhcp
 ip nat enable
 no shutdown
exit
interface fa0/1
 ip nat enable
 no shutdown
exit
interface fa0/1.10
 ip nat enable
 no shutdown
exit
interface fa0/1.20
 ip nat enable
 no shutdown
exit
interface fa0/1.30
 ip nat enable
 no shutdown
exit
interface fa0/1.40
 ip nat enable
 no shutdown
exit
ip nat source list 1 interface FastEthernet0/0 overload
ip nat source static tcp 172.16.30.3 20 interface FastEthernet0/0 20
ip nat source static tcp 172.16.30.3 21 interface FastEthernet0/0 21
ip nat source static tcp 172.16.30.3 80 interface FastEthernet0/0 80
