Static NAT Public-Private Forwarding on 887VA
Ian Stephens
So, I have a bit of a problem getting out Natted Cisco 7960 working with our external SIP providers behind NAT.
We have a block of IPs available to us, however when I asign a static NAT rule for the internal phone, outgoing calls are fine but incoming provides no audio.
We have no ACL blocking or anything, it's fully open to the outside world with the IP assigned to it via NAT.
Our static NAT rule for the phone:
ip nat inside source static 192.168.0.250 xxx.xxx.xxx.xxx
NAT is configured on the phone, with the external IP set correctly.
Also, after a while, it seems as the the registration times out or something because incoming calls no longer work.
I thought a static NAT rule would just allow full access to incoming connections to the internal IP specified?
Your help, thoughts, suggestions and tips are greatly appreciated.
Our main router config (with unnecessary information removed):
version 15.1
no service pad
hostname r1.essex.xxxx.xxx
boot-start-marker
boot system flash c880data-universalk9-mz.151-4.M3.bin
boot-end-marker
no logging buffered
enable secret 5 xxxxxx
enable password xxxxxx
no aaa new-model
memory-size iomem 10
no ip source-route
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.0.50 192.168.0.255
ip dhcp pool NET-POOL
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 8.8.8.8 8.8.4.4
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
controller VDSL 0
no ip ftp passive
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
ip address 81.138.131.190 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxxxxxxx
ppp chap password 0 xxxxxxxxx
ppp ipcp route default
no cdp enable
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static 192.168.0.250 xxx.xxx.xxx.xxx <-- THE PHONE's STATIC RULE
access-list 101 permit ip any any
ROBERTO TACCON
Level 4
Level 4
Have you try:
1) disabling NAT ALG for SIP ?
no ip nat service sip udp port 5060
2) change the timeout for NAT
ip nat translation timeout 1800
ip nat translation tcp-timeout 1800
3) check the PHONE SIP/RTP protocolos timeout/registration timers // NOT negotiate but use a single VOICE codec on the PHONE
4) upgrade the IOS to MAIN/STABLE version M ?
P.S.: if you want you can send me by email also the "sh tech"  for checking also the CPU problem
ROBERTO TACCON
Level 4
Level 4
Have you try:
Roberto,
Thank you for also looking at this topic.
I have just applied the following directive:
I will see how it goes and post my feedback.
I have changed the NAT timeouts in the past, but that didn't fix anything.
I thought a static NAT directive would always forward all ports and data on to the private IP, therefore timeouts didn't matter because the port was opened each time an incoming request came in.  Am I right?
We are currently running the following on the router:
Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
Thank you again for your assistance.
Roberto,
I can confirm that voice data is now working for incoming calls!
Using the following command:
I'll just wait now to make sure the registration doesn't time out.
I'll keep this post updated.
Thanks!
use "sh ip nat translations verbose" and check for the timeout
