Static NAT
Najib Akbari
I knew the concept and configuration of NAT and my confusion is :
for example : static (inside,outiside) 117.55.207.59 192.168.1.10 netmask 255.255.255.255
my confusion is the 'netmask' in syntax because static NAT is a one 2 one solution that we can use,
so what is the advantage of using subnet mask ? is it for binding a valid subnet to a privet subnet ?
or is it for binding a public one IP addr to a private subnet? or somthing else, then if its for binding
subnet to subnet then how static NAT works ?
thanks
Hi Sayed,
The purpose of the subnet mask is to give the range of addresses to be statically translated.
I am going to giev you an example...
static (in,out) 1.1.1.1 2.2.2.2 netmask 255.255.255.255
The above NAT translates the internal 2.2.2.2 to 1.1.1.1 and this is indeed a one-to-one translation.
static (in,out) 1.1.1.0 2.2.2.0 netmask 255.255.255.0
The above NAT translates the entire 2.2.2.0/24 to 1.1.1.0/24
static (in,out) 1.1.1.32 2.2.2.32 netmask 255.255.255.224
The above NAT translates 2.2.2.0/27 to 1.1.1.0/27
So, you see that the static NAT is a static translation but it can include an entire subnet or just specific IPs.
Hope it helps.
Federico.
Hello Dear Federico,
thanks for your usefull explanation, it has clarified my confusion but a little more clarification needs :
when we run static Nat command ( one 2 one )then the xlate table builds and we can see which real IP is binded to which mapped IP by show xlate command.
but when we run a static command that binds a subnet 2 subnet then its shows by show xlate just a subnet binded to a subnet and its not clear that which real IP of the private subnet is binded to which mapped IP of the public subnet.
- so is it automatically binds the private subnet IPs to Public subnet IPs respectively ? bcz it should be clear when we wants to publish a server to internet that which private IP is binded to which Public IPs in the range of two subnets ?!!.
- in case that we want to bind a subnet 2 subnet, then can we use Static PAT ? or its just possible with static NAT only ?
so please give me more information.
thanks
Najeeb
