Static nat
ziziahmed9
Hy everyone
Please I have problem with cisco router
I configured static nat on router , when I run show ip nat transactions,  the internal and external addresses that I configure appear but when capture packets outside the source ip doesn't translated ?
Thank
21 Replies 21
if the NAT transaction show IP not IP + L4 ports then the NAT is not work, what you see is static NAT you config not what router NATing
exactly I see just IP without Port ? How can I resolve this problem and enable static nat?
TS point to check
1- make sure that you config
ip nat inside
ip nat outside
2- Check if traffic is enter from inside and exit from outside interface.
3- make double check that IP is correct.
Because when now I work with dynamic nat , it works but static no ?
can I see the NAT config
The current config (dynamic nat)?
I need config for following:-
1- routing config in  router
2- interface config
3- dynamic NAT config
4- static NAT config
this is static NAT
Router(config)#ip nat inside source static 10.0.0.2 59.40.40.1
Router(config)#interface fa0/0
Router(config-if)#ip nat inside
Router(config)#interface fa0/1
Router(config-if)#ip nat outside
S* 0.0.0.0/0 [1/0] via 192.168.36.1
192.168.36.0/24 is variably subnetted, 4 subnets, 2 masks
C 192.168.36.0/24 is directly connected, Ethernet0/1
L 192.168.36.55/32 is directly connected, Ethernet0/1
L 192.168.36.80/32 is directly connected, Ethernet0/1
L 192.168.36.81/32 is directly connected, Ethernet0/1
S 192.168.42.0/24 [1/0] via 192.168.43.2
192.168.43.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.43.0/24 is directly connected, Ethernet0/0
L 192.168.43.1/32 is directly connected, Ethernet0/0
S 192.168.44.0/24 [1/0] via 192.168.36.66
 i remove static NAT and replace it with dynamic configuration :
Router(config)#interface eth0/0/0
Router(config)#access-list 1 permit 192.168.0.0 0.0.255.255
Router(config)#ip nat pool MY_POOL 4.4.4.1 4.4.4.5 netmask 255.255.255.0
Router(config)#ip nat inside source list 1 pool MY_POOL
the routing not show the real IP and mapped IP ??
Hello
Usually when you perform static nat and dynamic nat together, you would negate the static nat address from the dynamic nat ACL
Example
access-list 1 deny host 192.168.0.2
access-list 1 192.168.0.0.0.255.255
ip nat inside source static 192.168.0.2 4.4.4.6
However from your OP the static nat addressing does not reflect either an internal or external host currently active within or towards your network, unless that is you are not showing all the correct information?
Kind Regards
Paul
ziziahmed9
Sorry , I have mixed my config and the config that I based on .
this is static NAT
Router(config)#ip nat inside source static 192.168.42.43 192.168.36.80
 i removed static NAT and replaced it with dynamic configuration :
Router(config)#ip nat pool MY_POOL 192.168.35.80 192.168.35.100 netmask 255.255.255.0
how three device connect to same interface ?
the ip address of ethernet 0/1 is 192.168.36.55/32 but the others I think that are added due to NAT
correct and it answer for why the static is not work
you use NAT 1:1 to IP and dynamic so you must start config the router again in this seq
no ip nat outside
no ip nat inside list
clear ip nat <<- apply this at least three times
ip nat inside static
ip nat outside
then check the
show ip nat translation
