Static PAT for MS Exchange
wissamnad
Im having a weird issue; I can ping my exchange, connect to it remotely (rdp) through the internet eventhough I am specifying the ports in my static pat. If I add the  overload command to my Exchange pool then its blocking all the  unspecified ports in my static pat. Am I missing something in the  following config?
Exchange public ip: 1.1.1.1 - Internal: 192.168.10.10
Users Public IP: 2.2.2.2 - Internal (192.168.1.0)
ip nat pool Exchange 1.1.1.1 1.1.1.1 prefix-length 30
ip nat pool Client_Access 2.2.2.2 2.2.2.2 prefix-length 30
ip nat inside source list 120 pool Client_Access overload
ip nat inside source list 121 pool Exchange
ip nat inside source static tcp 192.168.10.10 25 1.1.1.1 25 extendable
ip nat inside source static tcp 192.168.10.10 80 1.1.1.1 80 extendable
ip nat inside source static tcp 192.168.10.10 110 1.1.1.1 110 extendable
ip nat inside source static tcp 192.168.10.10 443 1.1.1.1 443 extendable
ip nat inside source static tcp 192.168.10.10 587 1.1.1.1 587 extendable
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 120 permit ip 192.168.1.0 0.0.0.255 any
access-list 120 permit ip host 192.168.2.5 any
access-list 120 permit ip host 192.168.2.6 any
access-list 120 permit ip host 192.168.10.3 any
access-list 121 permit ip host 192.168.10.10 any
Abzal
Level 7
Level 7
Here is very useful info about your situation:
NAT Best Practices
Q. Are there any NAT best practices?
A. Yes. These are the NAT best practices:
  1. When using both dynamic and static NAT, the ACL that sets the rule  for dynamic NAT should exclude the static local hosts so there is no  overlap.
  2. When deploying ISPs load balancing with NAT interface overload, the  best practice is to use route-map with interface match over ACL  matching.
  3. When using pool mapping, you should not use two different mapping (ACL or route-map) to share the same NAT pool address.
  4. When deploying the same NAT rules on two different routers in the failover scenario, you should use HSRP redundancy.
  5. Do not define the same inside global address in Static NAT and a Dynamic Pool. This action can lead to undesirable results.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_q_and_a_item09186a00800e523b.shtml
Hope it will help.
Best regards,
Abzal
