Static route cleanup
Bill19795_2
I am going through several devices where static routes have been used and I am migrating them to EIGRP internally. I want to know of a command I can use on the routers to verify that once I remove the static route EIGRP knows about the routes and will insert them into the routing table. I am currently using
Show ip eigrp topology
But wanted to know if that was the best command or not.
I also have some devices that are connected to an MPLS provider and are using BGP so I need to know if BGP also has a route to that network once I remove the static routes.
Thanks.
Giuseppe Larosa
Hello Bill,
This is the best command you can use for this check unless you make the static route floating with AD 201 for example
you can filter with
sh ip eigrp topology
example:
sh ip eigrp topology 172.24.133.0/24
IP-EIGRP (AS 100): Topology entry for 172.24.133.0/24
  State is Passive, Query origin flag is 1, 2 Successor(s), FD is 1766912
  Routing Descriptor Blocks:
  172.24.128.221 (FastEthernet0/1), from 172.24.128.221, Send flag is 0x0
      Composite metric is (1766912/1764352), Route is External
      Vector metric:
        Minimum bandwidth is 2048 Kbit
        Total delay is 20200 microseconds
        Reliability is 255/255
        Load is 255/255
        Minimum MTU is 1500
        Hop count is 2
      External data:
        Originating router is 172.24.128.65
        AS number of route is 0
        External protocol is Static, external metric is 0
        Administrator tag is 0 (0x00000000)
  172.24.128.217 (FastEthernet0/0), from 172.24.128.217, Send flag is 0x0
      Vector metric:
        Load is 255/255
        Minimum MTU is 1500
        Hop count is 2
      External data:
you can use sh ip eigrp topology
b)
sh ip bgp
before and after static route removal:  hint if you use the network command in BGP you should be fine if you redistribute EIGRP into BGP as discussed in other threads you should be fine also
Hope  to help
Giuseppe
