Static route done..can't ping other PC?
abdul201188
I've made a static route between a  Cisco Router 1760 and a Cisco Router 2651xm using crossover cable to  connect to their Fast-Ethernet ports
so this is the configuration:
2651xm(config)#ip route 192.168.10.0 255.255.255.128 192.168.1.0.
and the other router's configuration:
Same thing.
The IP of the 2651xm is 192.168.10.2
The IP of the 1760 is 192.168.10.1.3
I'm I doing it wrong? is the destination wrong? I can't seem to ping any  other IP. I've got another laptop. I've put a static IP of  192.168.10.5, the primary Laptop is using has an IP of 192.168.1.138.  I'm trying to PING the 192.168.10.5 laptop. But this doesn't work.
Please help.
Sorry to mention, the 2561xm has another interface connected to a Cisco 2950 switch..with an IP of 192.168.1.3
35 Replies 35
The 192.168.22.x network is on a /25 subnet. 255.255.255.128.
just use a 192.168.x.0/24 instead and it will work with the 192.168.22.0/24 between the routers  because I really don't understand exactly what you did with all the contradicting and partial infos you gave us up to now.
Regards.
Alain.
This is the static route on the 1760.
CROUTER1760#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.22.1 to network 192.168.1.0
     192.168.22.0/25 is subnetted, 1 subnets
C       192.168.22.0 is directly connected, FastEthernet0/0
S*   192.168.1.0/24 [1/0] via 192.168.22.1
So from the 1760 you should be able to ping 192.168.1.x  being the ip address of 2651xm and the 192.168.1.x host if
firewall disabled and it has the correct default gateway.
Regards.
Alain.
So i should use 192.168.1.4 as the gateway?
for the 192.168.1.x host: yes
Alain.
Now this is weird..the 1760 can ping the IP 192.168.1.4 and the main internet router which is 192.168.1.254, but other than that it can't.
really you should post an uptodate  diagram with all ip addressing info as well as where the PCs are and also the latest configs from all devices as well as IP config of hosts. It will be much simpler to understand your problem because this is still very vague about the devices you want to ping between and their position in the network.
Alain.
Cisco 2651xm has 2 ports
fa0/0 has an IP of 192.168.22.12
fa0/1 has and IP of 192.168.1.4 (this port is connected a Cisco Catalyst 2950 24 port switch)
Cisco 1760 has 1 port:
fa0/0 has an IP 192.168.22.13
Laptop 1 has an IP 192.168.1.138 with the default gateway of 192.168.1.254
Laptop 2 has an  IP 192.168.22.15 with the default gateway of 192.168.1.4
As I already said this won't work:  the default-gateway must be in the same subnet as the PC
Alain.
Yeah, I get it now
Laptop 1 uses the gateway 192.168.1.254
Laptop 2 uses 192.168.22.14
where is laptop 2 connected to ?
To a normal 24 port Netgear Switch, the Netgear switch is connected to the Cisco Switch.
what's the use of the 1760 router then ?
I suppose they are in the same vlan( both PCs) and the 192.168.22.x on the 2651xm is going to 1760 ?
Alain.
Static route between them, i'm using it's FastEthernet port to connect to the 2651xm router..they don't have serial WAN cards.. WIC 1T
The problem, the router has 1 fastethernet port....
