Static Route fails to install
amit.vashishtha
Hello All ,
Need your help to understand this situation . Below is the topology
CE IP - 172.18.10.10 /30
PE IP - 172.18.10.9/30
I had configured  some floating static route on the PE towards CE .
ip route vrf ABC 10.10.0.0 255.255.255.0 172.18.10.10 250
ip route vrf ABC 172.17.0.0 255.255.255.252 172.18.10.10 250
ip route vrf ABC 172.24.0.0 255.255.255.224 172.18.10.10 250
The routes were installed correctly till PE - CE link was UP as next hop IP was showing as connected .
Now the link has been removed and I am receiving a supernet of 172.16.0.0/12 from PE2 via MPBGP  . Although the 1st static route for 10.10.0.0 is showing in routing table , the other 2 ( 172.17.0.0 & 172.24.0.0 ) donot show .
I believe that as both the routes and next hop fall under the supernet , the static route is not installing . But I dont know why is this behaviour . I tried to remove the distance 250 from both the routes , but still the static route doesnot install . I tried this on GNS3 but got the same results .
Can anybody help in understanding this .
14 Replies 14
mfurnival
Level 4
Level 4
Your static routes should still be valid even if you receive the supernet because your static routes have a longer subnet mask. Could you post the running config from PE1 and a "show ip route" please?
PE1#sh ip route vrf ABC 172.18.10.10
Routing Table: ABC
Routing entry for 172.16.0.0/12, supernet
  Known via "bgp 1", distance 200, metric 0, type internal
  Last update from 2.2.2.2
  Routing Descriptor Blocks:
  * 2.2.2.2 (default), from 2.2.2.2
      Route metric is 0, traffic share count is 1
      AS Hops 0
      MPLS Required
PE1#sh ip route vrf ABC 172.17.0.0
Routing Table: ABC
      AS Hops 0
      MPLS Required
Also when I tried on GNS3 , and run a debug , it showed that " static route table deleted "
Can you post the debug you got on gns3.
Alain
Amit,
Can you please post what I have asked for?
"show run"
"show ip route"
"show ip route vrf ABC"
OK , I tried to make a simple topology again on GNS3 which looks like :
R1 ----- R2 ----- R3
The running config is attached below .
As you can see that static route for a shorter prefix is applied with a next hop IP of a shut interface , I ahve advertised a supernet of this complete range from R3 via BGP . R1 prefers to install the longer prefix learnt via eBGP rather than the static route .
Debug on R1 shows :
R1#
*Mar  1 00:31:17.383: IP-Static:  1.1.1.128 255.255.255.128 1.1.1.10 Path = 2 5 6 8, route table deleted, recursive flag set
R1#
*Mar  1 00:32:17.387: IP-Static:  1.1.1.128 255.255.255.128 1.1.1.10 Path = 2 5 6 8, route table deleted, recursive flag set
R1#sh run
Building configuration...
Current configuration : 1211 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
interface Loopback11
ip address 11.11.11.11 255.255.255.255
interface FastEthernet0/0
description --- To R2
ip address 1.1.1.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 1.1.1.9 255.255.255.252
shutdown
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
router bgp 1
no synchronization
bgp log-neighbor-changes
network 11.11.11.11 mask 255.255.255.255
neighbor 1.1.1.2 remote-as 2
no auto-summary
ip forward-protocol nd
ip route 1.1.1.128 255.255.255.128 1.1.1.10
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R2#sh run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
log config
hidekeys
interface Loopback22
ip address 22.22.22.22 255.255.255.255
description --- To R1
ip address 1.1.1.2 255.255.255.252
duplex auto
speed auto
description --- To R3
ip address 2.2.2.1 255.255.255.0
duplex auto
speed auto
router bgp 2
no synchronization
network 22.22.22.22 mask 255.255.255.255
neighbor 1.1.1.1 remote-as 1
neighbor 2.2.2.2 remote-as 3
no auto-summary
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R3#sh run
Current configuration : 1125 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
log config
hidekeys
interface Loopback33
ip address 33.33.33.33 255.255.255.255
ip address 2.2.2.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 3
no synchronization
network 1.1.1.0 mask 255.255.255.0
network 33.33.33.33 mask 255.255.255.255
neighbor 2.2.2.1 remote-as 2
no auto-summary
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Here is RT on R1 :
R1#sh ip route
Gateway of last resort is not set
     1.0.0.0/30 is subnetted, 1 subnets
C       1.1.1.0 is directly connected, FastEthernet0/0
     33.0.0.0/32 is subnetted, 1 subnets
B       33.33.33.33 [20/0] via 1.1.1.2, 00:14:30
     22.0.0.0/32 is subnetted, 1 subnets
B       22.22.22.22 [20/0] via 1.1.1.2, 00:14:30
     11.0.0.0/32 is subnetted, 1 subnets
C       11.11.11.11 is directly connected, Loopback11
R1#
R1#
R1#sh ip route stat
R1#
R1#sh run | i ip route
R1#
Amit,
You did not attach your running config or the output of the command requested.
Are you aware that a static route to a destination will not be inserted into the routing table if the next hop address is not reachable?
Its attached alongwith all the debugs . I think by reachability check ,the router does a recursive lookup for the next hop ( unless it is configured as being attached to a particular interface ) . In our case , the next hop IP is a part of the supernet being received via BGP .
Amit - it is as I said, R1 cannot resolve the next-hop (1.1.1.10) so it does not insert the static route into the routing table. The static route remains in the config but cannot be used because the router would not know where to send the packets. If you do a "no shut" on the fa0/1 interface you should see the static route added to the routing table.
Thts wht I want to understand why R1 cannot resolve next-hop  . I have a route for 1.1.1.10 in the route table .
R1#sh ip route 1.1.1.10
Routing entry for 1.1.1.0/24
  Known via "bgp 1", distance 20, metric 0
  Tag 2, type external
  Last update from 1.1.1.2 00:02:01 ago
  * 1.1.1.2, from 1.1.1.2, 00:02:01 ago
      AS Hops 2
      Route tag 2
But still route to 1.1.1.128 is preferred via bgp .
R1#sh ip route 1.1.1.128
  Last update from 1.1.1.2 00:04:20 ago
  * 1.1.1.2, from 1.1.1.2, 00:04:20 ago
      AS Hops 2
      Route tag 2
R1#
Amit, you have a route to 1.1.1.0/24, not 1.1.1.10.
The router is doing a recursive lookup to decide which exit interface to use for your static route. Because the next-hop address is not reachable (1.1.1.10) it cannot insert that route into the routing table.
I just tried configuring 1 more static route in R1 which is a seperate subnet i.e.
ip route 10.10.10.0 255.255.255.128 1.1.1.10
when I shut the fa0/1 interface on r1 , even though 1.1.1.128 route is removed from static , the other one which I just installed still remains . So this is not at all related to the interface being shut .
*Mar  1 00:07:00.759: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
  Last update from 1.1.1.2 00:01:55 ago
  * 1.1.1.2, from 1.1.1.2, 00:01:55 ago
      AS Hops 2
      Route tag 2
R1#
R1#sh ip route 10.10.10.0
Routing entry for 10.10.10.0/25
  Known via "static", distance 1, metric 0
  * 1.1.1.10
I beleive this is something related to the destination prefix and next hop being a part of the agregate route recived via BGP .
