Static Route Load Balancing
capajaron
Hi Guys:
I just wanna ask how to load balance a static route.
Scenario.
* We have to WAN connections S0/0 and S0/1.
What should be my command to force a route to either of the interfaces? Can anyone give me a couple of samples to load balance a static route between a number of interfaces.
Thanks in advance.
cliff
jackyoung
Level 6
Level 6
You can use :
ip route x.x.x.x y.y.y.y z.z.z.z
ip route x.x.x.x y.y.y.y a.a.a.a
where x.x.x.x is the destination subnet, e.g. 0.0.0.0 for default route
where y.y.y.y is the subnet mask for x.x.x.x subnet
where a.a.a.a & z.z.z.z is the next-hop IP address of the serial links. i.e. remote end serial IP address of two serial interfaces.
By using of two equal cost static route, it will provide load-sharing function.
Hope this helps.
devang_etcom
Level 7
Level 7
hi...
you can do this by confiugring the two static route with the same AD... you can do it like this
ip route x.x.x.x subnetmask interface serial0/0 (or you can use the ip address of the netxt hop)
ip route y.y.y.y subnetmask interface serial0/1 (or you can use the ip address of the netxt hop)
hope this will help you
rate this post if it helps
regards
Devang
Wilson Samuel
Level 7
Level 7
Also you could use PBR to do a static Load Balance by deciding the Forwarding interface based on the Sender IP Address.
Wilson Samuel
