Static Route to Null0 interface is not appearing in ip routing table by default on 2921
Robbert100
I have tried same config on 1721 and  892 and it shows there.
on 892
R13#sh run | s ip route
ip route 0.0.0.0 0.0.0.0 30.0.0.254
ip route 192.168.0.0 255.255.0.0 Null0  ------
on 892 routing table
S 192.168.0.0/16 is directly connected, Null0
The S route is missing on same config on 2921 ios version 154-3.M1
Do you have advise how to enable static routes to null0 interface to appear in ip routing table?
Robert
Robbert100
The solution for that problem was upgrading the IOS version to Version 15.4(3)M4
