Static Route Tracking (Primary and Backup Static Routes)
AMU
Dear All,
               I am looking for a solution for the following scenario. Any help in this regard would be highly appreciated.
There is one service running on servers which has additional virtual IP (30.30.30.1/30) which could be active on Site A or Site B at any given time but not on both sides at the same time.  I need  to use static routing on my "Layer 3 Device" which is connected to both Site A and Site B.  I need to enable static route tracking to find out whether this Virtual IP is active on Site A or Site B and then somehow automatically change the routing table entry in the  "Layer 3 Device" i.e.
If Virtual IP is active on Site A,
route via  Site A Switch HSRP  Gateway
otherwise
route via Site B Switch HSRP  Gateway
is installed in the routing table.  I know about IP SLA feature but i think i can't use SLA feature in this scenario.  What options can I use in this scenario.
Thanks in advance.
AMU
27 Replies 27
if your layer 3 device is a Cisco device, you could use the IP SLA below. If 30.30.30.1 cannot be reached via Site A, the secondary route via Site B will be used:
Layer 3 Device
interface GigabitEthernet0/0
description Link to Site A
track 1 ip sla 1 reachability
ip sla 1
icmp-echo 30.30.30.1 source-interface GigabitEthernet0/0
frequency 5
ip sla schedule 1 start-time now life forever
ip route 30.30.30.0 255.255.255.252 GigabitEthernet0/0 track 1
ip route 30.30.30.0 255.255.255.252 GigabitEthernet0/1 200
Thanks for your Answer Georg,    I have already tried IP SLA but it is not working in my scenario because I am not tracking the reachability for gateway/nexthop IP but the address itself 30.30.30.1/32.
the configuration I posted does exactly that: it tracks the reachability of 30.30.30.1 on Site A. If 30.30.30.1 cannot be reached on Site A, traffic for that virtual IP will go to Site B.
Maybe I misunderstand your setup...
Hello
So why do you need static routing? -How is this server active on either either site, How is it addressing currenlty being advertied by either site
Kind Regards
Paul
Hi Paul,
I can't  use dynamic routing on this "Layer 3 Device". The Servers1/2 and Switches 1/2 are OSPF capable and as soon as this address is active on either site, they are propagated through the OSPF to the Switches1/2 on relevant site.
AMU
Hello
Apologies here - but it still doesn’t verify your topology
you show a L3 device in between two sites so your not extending you lans across each site but each site has dynamic routing active
Unless u am looking at the the wrong way around and given your topology- how can a server reside in both sites and have the same vip  - are you using virtualisation (lisp) etc ??
Or is it this server is upstream from both sites only accessible via the L3 device
Kind Regards
Paul
Hi Paul,
               Switches 1/2 are and Servers1/2 are running OSPF.  The VIP 30.30.30.1/32 is active and available On Server1/2 by an application but either on Site A or Site B at any given time. To explain the scenario, Say be default the VIP is active and available on Site A. Static Routing  on "Layer 3 Device"
192.168.10.0/24 via 192.168.10.X (HSRP IP on Switches 1/2,  GW)  Site A
192.168.20.0/24 via 192.168.20.X (HSRP IP on Switches 1/2,  GW)  Site B
30.30.30.1/32 via   192.168.10.X            (in case it is available on Site A, need to somehow track whether it still available through Site A GW  192.168.10.X)
If there is some issue with Site A Servers than the site Failover  is performed. The VIP is not available for some time say 5 minutes but then It is active and available now on Site B.  Static Routing  on "Layer 3 Device" should automatically now adopt to
30.30.30.1/32 via   192.168.20.X            (Adapted the routing entry to Site B, need to somehow track further whether it still available through Site B GW  192.168.20.X, another Site Failover may occur and it will be again available at Site A and we need to adpot the routing again to first scenario)
Thanks and Best  Regards,
AMU
I am just thinking, why not use two IP SLAs, and if one is down, after a delay of 360 seconds (or whatever value you need), an EEM script installs a default route towards the other site. It would look like this:
interface GigabitEthernet0/1
description Link to Site B
track 2 ip sla 2 reachability
ip sla 1
frequency 5
ip sla 2
icmp-echo 30.30.30.1 source-interface GigabitEthernet0/1
frequency 5
ip sla schedule 2 start-time now life forever
ip route 0.0.0.0 0.0.0.0 ip_address_site_A
event manager applet TRACK_VIP_DOWN
event timer countdown time 360
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 ip_address_Site_A
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 ip_address_Site_B
action 5.0 cli command "end"
event manager applet TRACK_VIP_UP
event track 1 state up
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 ip_address_Site_B
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 ip_address_Site_A
Hi Georg,
I was also thinking in this direction, combination of IP SLA and EEM. Will try your solution and let you know. Thanks.
Hello @Georg Pauwen
ip sla 1
frequency 5
ip sla 2
frequency 5
How can you have default routes on the single L3 device that interconnects both of these routing domains when the two sites also have default routes pointing the the L3 devcie -Surely this incur a loop would it not?
Kind Regards
Paul
Hello Paul,
not sure what you mean, how would the loop occur ? At any given time, there would be only one default route on the layer 3 device. That default route would point to the site where the VIP is active.
Either way I cannot test it, better ask the OP...
Hello Paul,
Site X default route <> L3 device default route to site X ??(Outch) !
Kind Regards
Paul
Hi Georg and Paul,
Site A/B switches have a default route to Layer 3 Device and Layer 3 Device have site specific static routes to Site A and Site B networks plus the VIP static routes. For external networks there is a default route to the one level above. No loop.
Thanks.
Hello
I understand that’s why I was querying the EMM example @Georg Pauwen  provided as has it had defaults pointing to your sites
Kind Regards
Paul
