if rib-has-route on IOS XE
Leonid Voronkin
Hello, community.
Cisco IOS XR has feature "if rib-has-route" in route policy. Is it possible to implement the same functionality on IOS XE?
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
lucasfreitas83
Hello Leonid,
I think haven't the same command, but verify if policy (If-Policy-In) contains that you need.
https://www.cisco.com/c/en/us/td/docs/routers/xr12000/software/xr12k_r4-0/routing/configuration/guide/rc40xr12k_chapter7.html#con_1194522
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future.
Best regards,
Lucas Freitas
You give me link on IOS XR. I want to realize it on IOS XE
I know there is no the same command. But may be this functionality can be implemented by some complicated construction
