Static Routes for VNC Connection
tonyplueard
I am trying to setup a connection to a remote non domain workstation that is behind an unmanaged router.
My routes aren't working and any help would be greatly appreciated.
The SVI for VLAN 163 in on router 3
The gateway for the 92 network is on the unmanaged router
on router 1 i have (ip route 192.168.92.0 255.255.252.0 10.1.1.18)
on router 2 I have (ip route 192.168.92.0 255.255.252.0 10.1.1.21)
on router 3 I have (ip route 192.168.92.0 255.255.252.0 192.168.163.53)
6 Replies 6
@tonyplueard
 what about the route back? The packet will leave Router 1 and get to the unmanaged router but you need to have the return.
There is a route on the unmanaged router 0.0.0.0 0.0.0.0 192.168.163.1 to get out to the production network.
right, you also need the route on Router 3 sending to Router2 and in Router2 sending to Router1
I also know that the route out works as we were using a different solution before that had to be routed out. My issue now is that I am trying to gain access in first.
wouldn't the gateway of last resort cover that which all the routers have?
No. The route must be explicit added to every route if you are using static route.
