STATIC ROUTING AND BGP
shaahin13631363
I have a BGP route on my Nexus switch for 179.217.249.0/24 . Now I want to write a static route for 179.217.249.32/27 but the BGP route is always chosen . Can you guide me how to write correctly this route So that the static route is always selected for the subnet 179.217.249.32/27?
14 Replies 14
@shaahin13631363
  static route should be prefered over BGP as it has lower administrative distance.
Are you sure the static route is correct configured?
shaahin13631363
hi But don't forget that the router always chooses the longest match route to forward traffic so if you have a longer BGP prefix it will win over the static route
i find this
Both are different prefix so NX-OS must add both into rib' do you see both prefix??
MHM
no only see 179.217.249.0/24
show ip route 179.217.249.62
via 172.19.32.93, [20/0], 21w6d, bgp-13135, external, tag 43754
Then nexus not add static at all.
Can I see how you add static route
MHM
ip route 179.217.249.32/27 172.16.12.2
hi , Where should I look?
How yoh add it ?
Under vlan or under vrf or in global ?
If under vlan are yoh sure vlan is UP and add to DB?
MHM
in global mode also we use default vrf only
let me check how we can trouble static in NSK
MHM
thank you all
route is working now
ip route clear*
you are welcome bro
MHM
Hello
Even though the static route will be added to the rtr/sw it will NOT be entered into the route table unless that static route has a valid next-hop address and that next hop address is reachable ( directly or recursively)
So what you are stating suggests the above is  the possible route cause of that static route not working
Kind Regards
Paul
