Static Routing Noob
adam.cattell1
Hello, I'm taking an advanced routing course at college and we've been tasked with a project to configure routing by only using static routes to make each PC pingable from all the other PCs. I've been at it all day and I'm just stuck. I don't know what to do with the router in the middle. I think I have everything connected but again, I'm really not sure what I'm doing.
this project is due on Monday 4/4 if anyone is able to help me before than please contact me through discord @  giraffe#0001. I don't know if I'll see this in time on here, but I'm usually always on discord. ill also attach the file here.2022-04-01 22_12_49-Greenshot.png
I am not sure that this version (6.2) saves all the setting correctly, especially the PC settings. Make sure everything is configured as below:
Router0#sh run
Building configuration...
Current configuration : 788 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router0
ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 172.16.3.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
ip address 172.16.55.1 255.255.255.0
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 172.15.55.2
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
PC0
IP: 172.16.3.2/24
DG: 172.16.3.1
Router1#sh run
Current configuration : 785 bytes
version 12.2
hostname Router1
ip cef
no ipv6 cef
ip address 10.10.8.1 255.255.255.0
duplex auto
speed auto
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.2
line con 0
line aux 0
line vty 0 4
login
end
PC2
IP: 10.10.8.2/24
DG: 10.10.8.1
Router3#sh run
Current configuration : 793 bytes
version 12.2
hostname Router3
ip cef
no ipv6 cef
duplex auto
speed auto
ip address 192.168.100.1 255.255.255.0
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.100.2
line con 0
line aux 0
line vty 0 4
login
end
PC3
IP: 192.168.1.2/24
DG: 192.168.1.1
Router4#sh run
Current configuration : 783 bytes
version 12.2
hostname Router4
ip cef
no ipv6 cef
ip address 10.1.10.1 255.255.255.0
duplex auto
speed auto
ip address 10.1.17.1 255.255.255.0
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.17.2
line con 0
line aux 0
line vty 0 4
login
end
PC4
IP: 10.1.10.2/24
DG: 10.1.10.1
Router5#sh run
Current configuration : 1239 bytes
version 12.2
hostname Router5
ip cef
no ipv6 cef
ip address 172.16.55.2 255.255.255.0
duplex auto
speed auto
ip address 10.10.10.2 255.255.255.0
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
no ip address
interface FastEthernet6/0
ip address 192.168.100.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet7/0
ip address 192.168.10.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet8/0
ip address 10.1.17.2 255.255.255.0
duplex auto
speed auto
ip classless
ip route 172.16.3.0 255.255.255.0 172.16.55.1
ip route 10.10.8.0 255.255.255.0 10.10.10.1
ip route 192.168.10.0 255.255.255.0 192.168.4.1
ip route 192.168.1.0 255.255.255.0 192.168.100.1
ip route 10.1.10.0 255.255.255.0 10.1.17.1
line con 0
line aux 0
line vty 0 4
login
end
9 Replies 9
Hello
The PT you posted isnt readable, However see below for a solution but before you apply this configuration remove all current static routing  for al rtrs.
top left rtr
ip route 0.0.0.0 0.0.0.0 172.15.55.x (primary rtr ip)
bottom left rtr
ip route 0.0.0.0 0.0.0.0 10.10.8.x (primary rtr ip)
bottom rtr
ip route 0.0.0.0 0.0.0.0 192.168.10.x (primary rtr ip)
top right rtr
ip route 0.0.0.0 0.0.0.0 10.1.17.x (primary rtr ip)
bottom left rtr
ip route 0.0.0.0 0.0.0.0 192.168.100.x (primary rtr ip)
primay rtr
ip route 172.15.55.0 255.255.255.0 172.16.55.x (top left rtr ip)
ip route 10.10.8.0 255.255.255.0 172.16.55.x (bottom left rtr ip)
ip route 192.168.10.0 255.255.255.0 192.168.10.x (bottom rtr ip)
ip route 10.1.17.0 255.255.255.0 10.1.17.x (top right rtr ip)
ip route 192.168.100.0 255.255.255.0 192.168.100.x (bottom left ip)
Kind Regards
Paul
I suspect (because I've had not double checked) what @paul driver is correct.  However, it may be unclear to you what and why Paul suggested what he did.
Routing looks at an incoming packet and compares that packet's destination address with all its known networks (i.e. their prefixes) and aggregates of such, or, and lastly, a "none of the above" (the latter is not done, by default).  Matching occurs from the most specific match to the least specific match.
In your diagram you have five networks containing hosts and five networks as transits between routers.
For packets to flow between devices, each router needs to know where to direct a received packet.  (If it doesn't, the packet is dropped.)
By default, routers know all the networks directly connected to them, but need to (somehow) be informed of networks not directly connected so they can forward the packet to the correct egress interface and to, sometimes, a known IP to forward packets to.
So, Paul "informs" the central router of all five (not directly connected) host networks and what IP to forward those packets to (the latter implying the router knows how to get to those IPs, which it does, as they are all directly connected networks.)  (BTW, Paul is assuming all those host networks are /24, but they could be smaller or larger.  In fact, using the old Classful network rules, I believe two are Class As, /8, one a Class B, /16, and two Class Cs, /24).
For the routers, either they need to be "informed" of the four other host networks, going via the central router, or, what Paul has done, is "inform" them, send "unknown" destinations to the central router.  I.e. one "wildcard" route on each host edge router replaces four routes that you would otherwise need.  (BTW, this would be the usual approach for a hub/spoke network.)
If you're still confused, post additional questions, because, the real goal, for such an assigned project, is to "learn" routing.
you explain more about this project than my professor has. thanks for this helpful information, it means alot to me!
hi paul! thanks for helping me out with this. it may not be readable due to my packet tracer being an older version, my school uses pt version 6.2. i've gone ahead and put a link to the file for you if you want to better look at mine. i was also wondering when you put the "x" in the command line what would i put for that? i'm also not sure if i have my ip configs correct. like i said i really dont know what im doing. i appreciate your help alot
Cisco Packet Tracer 6.2
here is also a different way of getting my file if you need it
my pt file
i added the commands in but the pc's still arent able to communicate with each other. i must be doing something else wrong that i dont know.
Hello
You had multiple configuration errors, all your host pcs had the incorrect default-gateways and on some rtrs you had duplicate addressing.
Please review the working PT file.
Kind Regards
Paul
hi paul, I tried opening your file and i keep getting the error
the file is not compatible with this version of Packet Tracer.
Not sure why i am.
since I was working on the file in the version (6.2) you are, I might as well send my revised file. PT versions are not backward compatible, unfortunately, so hopefully you can open this one.
Apart from the static routing, all of your PCs had either the wrong IP address/subnet mask/default gateway. The IP address assignments of the inter-router links were often wrong (wrong IP addresses/subnet), hence all static routes were wrong as well.
Have a look at the attached file, and try to make sense of it...
Hi George, I took a look at you file and was able to open it. I see all the work that you did, thank you I appreciate it! However, each PC is not pingable from all the other PCs. Not sure if it's something I'm doing wrong.
Router0#sh run
version 12.2
hostname Router0
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
PC0
IP: 172.16.3.2/24
DG: 172.16.3.1
Router1#sh run
version 12.2
hostname Router1
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
PC2
IP: 10.10.8.2/24
DG: 10.10.8.1
Router3#sh run
version 12.2
hostname Router3
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
PC3
IP: 192.168.1.2/24
DG: 192.168.1.1
Router4#sh run
version 12.2
hostname Router4
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
PC4
IP: 10.1.10.2/24
DG: 10.1.10.1
Router5#sh run
version 12.2
hostname Router5
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
no ip address
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
ip classless
line con 0
line aux 0
line vty 0 4
login
end
