delete post, thanks.
Izaz
11 Replies 11
use CLI
under RIP
config
no auto-summary
I've already done
no auto-summary
on both routers using CLI. The whole system breaks once I add that WAN connection and switch to RIP version 2 protocol.
Show ip interface breif in each route
I want to see it
I attached the PKT file.
Sorry I can not see it because I don't install PKT in my MACbook,
can you share here only RIP config and show ip interface brief ??
Not sure if this is what you meant. I've attached RIP and IP config for one of the ports.
As I inform before I don't have PKT in my Macbook,
just in CLI share the output for both router
show running-config
clock rate is huge different  one side 1200 and other 125000!!!
one is so fast and other is so slow.
why this ? correct it be at least half and see result.
Attache the PKI file instead. Zip it first.
Done, it should be attached now.
Still dont see it.
