stop ping between vlans
I have an Cisco ASA 5512x and an Cisco 3750x(Layer 3). My question is how do i stop being able to ping between vlans.
Best greetings from Christian Josiassen.
19 Replies 19
Hello @ChristianSchmidtJosiassen
Yes you can
Kind Regards
Paul
Is this on the L3 switch or the ASA?
Hello
That configuration is applicable to the ASA .
Kind Regards
Paul
So the next ACL would be 107?
Hello
maybe depends if you want to negate from the same interface/vlan or a different interface/vlan then you use a different acl
Kind Regards
Paul
