STP Query
AkbarAliSheikh
Hi All,
I have got 5 switches connected in star topology. The main switch to which rest of four switches connects is 3550 and running RSTP. Rest of the four switches are 3560X and running standard STP (IEEE). These four switches are all user facing interfaces. When ever some user accidentally plugs in a same cable to wall ports i get a broadcast storm over the network and everything crashes.
The details for the Main Switch as its ports are below:
spanning-tree mode rapid-pvst
VLAN0061
  Spanning tree enabled protocol rstp
  Root ID    Priority    32829
             Address     0011.202c.c280
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32829  (priority 32768 sys-id-ext 61)
             Aging Time 300
Interface        Role Sts Cost      Prio.Nbr Type
Fa0/1            Desg FWD 19        128.1    P2p Peer(STP)
Fa0/4            Desg FWD 19        128.4    Edge P2p
Fa0/7            Desg FWD 19        128.7    P2p
Fa0/8            Desg FWD 19        128.8    Edge P2p
Fa0/10           Desg FWD 19        128.10   Edge P2p
Fa0/11           Desg FWD 19        128.11   Edge P2p
Fa0/24           Desg FWD 19        128.24   Edge P2p
Interfaces that connect to the four access switches:
Interace1:
interface FastEthernet0/8
switchport access vlan 61
switchport mode access
no ip address
no snmp trap link-status
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
end
Interface2:
interface FastEthernet0/11
no ip address
duplex full
speed 100
end
Interface3:
interface FastEthernet0/24
no ip address
no logging event link-status
end
Interface4:
no ip address
end
STP details for the Access Switches as its' ports are below:
spanning-tree mode pvst
VLAN0061
  Spanning tree enabled protocol ieee
             Address     442b.0379.5580
             Aging Time  300 sec
Gi0/1               Desg FWD 19        128.1    P2p
Gi0/4               Desg FWD 4         128.4    P2p
Gi0/5               Desg FWD 4         128.5    P2p
Gi0/7               Desg FWD 4         128.7    P2p
Gi0/9               Desg FWD 19        128.9    P2p
Gi0/12              Desg FWD 100       128.12   P2p
Gi0/14              Desg FWD 4         128.14   P2p
Gi0/15              Desg FWD 4         128.15   P2p
Gi0/16              Desg FWD 4         128.16   P2p
Gi0/23              Desg FWD 4         128.23   P2p
Gi0/25              Desg FWD 4         128.25   P2p
Gi0/26              Desg FWD 4         128.26   P2p
Gi0/29              Desg FWD 19        128.29   P2p
Gi0/30              Desg FWD 4         128.30   P2p
Gi0/31              Desg FWD 4         128.31   P2p
Gi0/34              Desg FWD 4         128.34   P2p
Gi0/35              Desg FWD 19        128.35   P2p
Gi0/36              Desg FWD 4         128.36   P2p
Gi0/39              Desg FWD 4         128.39   P2p
Gi0/40              Desg FWD 4         128.40   P2p
Gi0/43              Desg FWD 100       128.43   P2p
Gi0/46              Desg FWD 4         128.46   P2p
Interface:
interface GigabitEthernet0/1
end
Many thanks for you help and advise in advance.
Hi Akbar,
For this issue a command has been implemented. Essentially you need to issue the spanning-tree portfast enable on each user interface (assuming they are in a dedicated LAN) . This command will disable stp on user switch ports and they will go in forwarding immediately with no delay. All the switch ports accessible and for the users should have portfast enabled while all the rest of the ports should be in shutdown if you are not going to use pvstp+
If you instead decide to upgrade the IOS to run PVSTP just set all the unused and user-accessible switch ports in an unused vlan.
Vlan database
Vlan 999 name unused
Apply
Exit
Conf t
Interface range fast x/y - z
Description ***User Accessible/Defined switch port***
Swi mo acc
Sw vlan access 999
End
Wr
The above code is very helpful ONLY if a stp instance per vlan is used(PVSTP) otherwise:
Conf t
Shut
End
Wr
With RSTP or a single stp instance anyway.just forgetting that on the main switch you have PVSTP enabled downgraded to the RSTP present on the other switches. You should not have portfast enabled on the main switch but only trunks and access ports for eventual servers.
Interface 1,2,3,4:
Description trunk to switch 1 location wherever
Sw encapsulation dot1q
Sw mo trunk
Sw nonegotiate
Speed 1000
Duplex full
Sw trunk vlan allowed vlan-list-you-want-tocross-the-trunk
Hope this helps
Alessio
milan.kulik
Level 10
Level 10
configuring
on the ports connecting your core 3550 switch to the other switches is the same like disabling STP there!
See http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_19_ea1/command/reference/cli2.html#wp2557315
for details.
So each of the edge switches "thinks" to be the STP root as not receiving any BPDUs from the core switch.
When a user connects a cable to two wall ports connected to two different edge switches, it creates an L2 loop in your LAN.
I'm not sure what happens exactly if that two ports belong to the same switch, it depends on you access port configuration details there.
I'd also recommend running the same STP mode on all switches - either RSTP or IEEE STP.
HTH,
Milan
Hi Akbar,
Vlan database
Apply
Exit
Conf t
Swi mo acc
Sw vlan access 999
End
Wr
Conf t
Shut
End
Wr
Interface 1,2,3,4:
Sw mo trunk
Sw nonegotiate
Speed 1000
Duplex full
Hope this helps
Alessio
