Strange ASR-1001 Access-lists behavior
RemsoO
I am trying to implement control plane policies on my test equipment, my cto is asking me to limit the ICMP max rate for all untrusted addresses. (I have to create an exception for knows hosts)
Having very little experience in CoPP, I believed that I could just Deny some hosts in the ACL so those wont match the rate limit class-map like this :
ip access-list extended ICMP
 deny icmp host 192.168.1.3 any
 permit icmp any any
My big problem is that ICMP-echoes are incrementing counters of the rate-limit class when sent from the denied host's address. I thought that denying a host in the ACL was going to prevent those echoes from matching this class. (It does with a bunch of other models that I tested and echoes are matching the default-class instead)
The point is that I wanted to add a second ACL to treat those trusted hosts in a different class, but given the fact that the first one is not working, I came here instead to prevent from making mistakes.
Could you tell me if more efficient solutions exists for this case of use ? Have you ever seen this kind of ACL behavior on 1000 series ?
class-map match-any ICMP
 match access-group name ICMP
policy-map COPP
 class ICMP
  police cir 8000
  conform-action transmit
  exceed-action drop
  violate-action drop
ASR1001# show policy-map control-plane
Control Plane
Service-policy input: COPP
Class-map: ICMP (match-any)
720 packets, 50240 bytes                                                   ===> Ping from .1.3 are incrementing this counter
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: access-group name ICMP
police:
cir 500000 bps, bc 15625 bytes, be 15625 bytes
conformed 720 packets, 50240 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
drop
violated 0 packets, 0 bytes; actions:
drop
conformed 0000 bps, exceeded 0000 bps, violated 0000 bps
Class-map: FRAGMENTS (match-any)
0 packets, 0 bytes
Match: access-group name FRAGMENTS
Class-map: class-default (match-any)
34410 packets, 2052766 bytes
5 minute offered rate 9000 bps, drop rate 0000 bps
10 Replies 10
To be honest I dont have much experience in this case but
Any ACL use for QoS or CoPP must be only permit not deny'
The traffic match permit it will control by CoPP not match permit it will pass without any limitations.
MHM
Any possibility that it could be platform specific ? Or maybe older software ? I can't find any documentation relating to how ACEs should be used with CoPP. ( except for the old ones )  plus my boss keeps saying that it has already been done. Altough I begin to doubt it by seeing a few topics saying the same as you. So why does the same setup works on a small old 890 series CPE ?
Good reference' I will make double check
Thanks for waiting
MHM
Found that in the IOS-XE Release 3S (the right one) manual :
 Here we can notice quite some deny, but it is only about egress icmp for Unreachables. Above it there is what i want to achieve but with telnet, sadly it looks perfectly similar to what I did...
No it not same
There is match-any in your code and that maybe explain why it match both deny and permit.
Remove match-any from your code
MHM
Still the same behavior, ran the test with an even older 7600 and it works. Guess it is cisco platform joys.
I also found this to illustrate what I was saying earlier about Telnet
can I see last code you use
MHM
class-map ICMP
policy-map COPP
 class ICMP
  police cir 8000
  exceed-action drop
  violate-action drop
Still the same behavior, however we can actually use denies with COPP with some other equipment, but I am still looking for an explanation of how I am supposed to provide a bypass for this control plane policy to my trusted hosts ?
are you run service-policy code ? without it there is no meaning of Policy map
MHM
Yep, control-plane -> service-policy input COPP otherwise would not be able to see packets matching those class-map
