Strange issue with Outgoing access-list and QoS
paris2london
Hi all
I have the following issue, which I guess may be due to my IOS version.
IOS (tm) 3700 Software (C3745-IK9S-M), Version 12.3(6b), RELEASE SOFTWARE (fc1)
When I apply an outgoing access-list to an interface, my QoS shaping ceases to function. When I remove the access-list the QoS shaping kicks in.
In this version of IOS are security access-lists and QoS shaping mutually exclusive? or do I need to configure additional paramaters.
Any ideas?
tdrais
Level 7
Level 7
Check this link.
On output acl are processes before most QoS. It does not explicitly say shaping but I suspect it is done after the ACL.
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a0080160fc1.shtml
Thanks for that.
I read the article, and the output ACL is processed before QoS.
My outgoing access-list has the 'reflect' option and is not processed, when I remove the 'relect' option, QoS kicks in.
Any ideas.
This is strange since reflexive acl modify the incoming access list and should not really affect the outbound traffic.
Sounds like a bug but its been a while since I used reflexive access lists. I generally use CBAC but you need the firewall feature set to do that.
This one sounds like a good case to call the TAC if you have a service agreement.
