Strange LAN Switch issue
waqas0612147
I am facing a very strange problem  currently.....i have two sites A and B .............on Site A i have a LAN switch cisco 2950 connected to  site B's switch  via a radio link(Redliner something) .Now the problem is that when i ping test the both sites via attaching laptops on both sites A & B my ping is fine while when i connect the switches on both sites and then test ping From site A to B then i get some drops ....Can anyone have some clue.???
Waqas
zubaircco
Hi Waqas,
We have a similar setup for one of our clients, we have a site A - B and then from site B to a mini site we have Cisco 3750 switch connected via a wireless radio link.
We had similar issues whereby we receive lots of packet drops between site B and the mini site over the wireless link.
We logged an incident with our wireless service provider and they came in a few times and aligned the radio's etc eventually until the problem was resolved.
Hope this helps, unless you can explain the connectivity methods in detail.
Thanks.
Zubair
5 Replies 5
Giuseppe Larosa
Hello Waqas,
check speed and duplex that are effective on switch ports. This is the first move
use sh interface typex/y
the same sh int  typex/y can give error counters in number and type if any
Hope to help
Giuseppe
zubaircco
Hi Waqas,
Thanks.
Zubair
@zubair u might be right as same happened to me once before and a little wireless adjustments would have solved the problem..but now the problem is that my wireless providers are saying its clear from there end moreover i am recieving gaints on the wireless uplink port ...below is the port status....any clue
sw1#sh interfaces f0/24 counters errors
Port        Align-Err     FCS-Err    Xmit-Err     Rcv-Err  UnderSize  OutDiscards
Fa0/24              0           0           0           2          0            0
Port      Single-Col  Multi-Col   Late-Col  Excess-Col  Carri-Sen      Runts     Giants
Fa0/24             0          0          0           0          0          0        364
Waqas,
How did you test with the laptop ? Did you mean you terminated the WAP on the lap ?
If it worked then the packets were through the Wireless SP only right ?
Could you increase the ping packet size and see ?
Would like to hear how you solved this though ..
tharak.
Tharak Abraham
Level 3
Level 3
Waqas,
Please hardcode speed and duplex and give a try
HTH,
Tharak
