strange messages while configuring CoPP !
kthned
Level 3
Level 3
I am trying to configure CoPP on 6500 switch (Sup2T). I get below error message on the console as soon as I add service policy under the control plan interface :(. Any idea what should I do ?
sw(config)#control-plane
sw(config-cp)#service-policy input policy-default-autocopp
sw(config-cp)#e
Jan 30 15:30:03.332: %EARL_CM-5-NOCAPMAP: No free capmap entry available
Jan 30 15:30:03.360: %EARL_CM-5-NOCAPMAP: No free capmap entry available
Jan 30 15:30:03.492: %QM-4-TCAM_ENTRY: Hardware TCAM entry programming failed for slot 1 intf CPP dir IN: <CONFIG_UPDATE_REQ> TCAM Req Error: FAIL (4): Low TCAM Entries (1)
Jan 30 15:30:03.492: %QM-4-TCAM_ENTRY: Hardware TCAM entry programming failed for slot 2 intf CPP dir IN: <CONFIG_UPDATE_REQ> TCAM Req Error: FAIL (4): Low TCAM Entries (1)
Jan 30 15:30:03.492: %QM-4-TCAM_ENTRY: Hardware TCAM entry programming failed for slot 5 intf CPP dir IN: <CONFIG_UPDATE_REQ> TCAM Req Error: FAIL (4): Low TCAM Entries (1)
Jan 30 15:30:03.504: %FMCORE-6-RACL_ENABLED: Interface Control Plane Interface routed traffic is hardware switched in egress direction
Jan 30 15:30:03.323: %EARL_CM-DFC2-5-NOCAPMAP: No free capmap entry available
Jan 30 15:30:03.355: %EARL_CM-DFC2-5-NOCAPMAP: No free capmap entry available
Jan 30 15:30:03.331: %EARL_CM-DFC1-5-NOCAPMAP: No free capmap entry available
Jan 30 15:30:03.371: %EARL_CM-DFC1-5-NOCAPMAP: No free capmap entry available
0 Replies 0
