strange reload of standby msfc
mohammedrafiq
I have two 6509 running as pair in two rooms.Both have TWO sup2 msfc as active and stanby.some how the both the standby sup2 reloaded same time on both switches,but we saw only parity eror on 1st switch active sup. any idea?
SW1
Feb 5 14:01:57 GMT: %MISTRAL-3-ERROR: Error condition detected: TM_DATA_PARITY_ERROR
Feb 5 14:01:31 GMT: %RUNCFGSYNC-6-SYNCEVENT:
Syncing Running Configuration to the Non-Designated Router
Feb 5 14:01:32 GMT: %RUNCFGSYNC-6-SYNCEVENT:
Syncing Startup Configuration to the Non-Designated Router
SW2
REGARDS,
mchin345
Level 6
Level 6
This error: %RUNCFGSYNC-6-SYNCEVENT: states a running configuration synchronization event has occurred. No action required for this error.
But this Mistral-3-Error is the most common errors from the Mistral ASIC on the MSFC are TM_DATA_PARITY_ERROR, SYSDRAM_PARITY_ERROR, SYSAD_PARITY_ERROR, and TM_NPP_PARITY_ERROR. Possible causes of these parity errors are random static discharge or other external factors.
