Stratacom - BPX - Checking for physical line errors
cachaves
What command, on a BPX, can be used to check for line (physical ine) errors (bit, parity, c-bit, etc). Would there be a different command if the port is a trunk port?
pkhatri
Level 11
Level 11
'dsplnerrs' will show you errors on a line while 'dsptrkerrs' will show you errors on a trunk.
Paresh
