Stuck at 10M internet access cisco 1841
bfeole001
fastethernet0/0 is the wan interface and I have no clue why it doesn't go above 10M when I run a speed test from directly behind the router. I'm plugged into a hatteras which says internally it's connected at 20M and full duplex on its lan interface. Any ideas?
Freedom of expression is customer-eoc-gw#sho running-config
Building configuration...
Current configuration : 6098 bytes
! Last configuration change at 11:28:06 EDT Tue Mar 22 2016 by xxx
version 12.4
hostname xxx-eoc
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.100.1
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp excluded-address 10.90.2.1
ip dhcp excluded-address 10.90.2.101 10.90.2.254
ip dhcp excluded-address 10.90.3.1
ip dhcp excluded-address 10.90.3.101 10.90.3.254
ip dhcp pool Voice-pool
   network 192.168.100.0 255.255.255.0
   next-server 666.555.48.107
   default-router 192.168.100.1
   dns-server 222.444.82.2 222.444.84.201
   option 150 ip 666.555.48.107
   option 66 ip 666.555.48.107
ip dhcp pool Switch-test-pool
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
ip dhcp pool vlan92
   network 10.90.2.0 255.255.255.0
ip dhcp pool vlan93
   network 10.90.3.0 255.255.255.0
ip domain name customerdomain.com
ip name-server 8.8.8.8
ip name-server 4.4.4.4
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vtp file vtp
username xxx privilege 15 secret 5
archive
 path flash:myconfig
 time-period 3
ip ssh rsa keypair-name somethingneato
ip ssh version 2
interface FastEthernet0/0
 description Connection to Hatteras$ETH-WAN$
 ip address 10.254.16.242 255.255.255.252 secondary
 ip address 222.444.117.18 255.255.255.252
 ip flow ingress
 --More--          ip flow egress
 ip nat outside
 no ip virtual-reassembly
 speed 100
 full-duplex
interface FastEthernet0/1
 description customer LAN$ETH-LAN$
 ip address 222.444.107.33 255.255.255.224
 ip flow ingress
 ip flow egress
 duplex auto
 speed auto
interface FastEthernet0/1/0
 switchport mode trunk
interface FastEthernet0/1/1
 switchport trunk native vlan 10
interface FastEthernet0/1/2
 switchport access vlan 254
interface FastEthernet0/1/3
 description Voice Demo (Edgemarc router)
 switchport access vlan 20
interface Serial0/0/0
 description Backup 1.5M XO T1 to ourcompany PH/HCFS/740920//TQW
 bandwidth 1568
 ip address 222.444.117.182 255.255.255.252
 ip nat outside
 no cdp enable
interface Vlan1
 shutdown
interface Vlan10
 ip address 10.100.0.250 255.255.0.0
 ip nbar protocol-discovery
 ip flow ingress
 ip flow egress
 ip nat inside
interface Vlan91
 ip address 10.90.1.1 255.255.255.0
 ip helper-address 10.100.0.29
 ip nat inside
interface Vlan92
 ip address 10.90.2.1 255.255.255.0
interface Vlan93
 ip address 10.90.3.1 255.255.255.0
interface Vlan100
 ip address 192.168.100.1 255.255.255.0
 ip nat inside
interface Vlan170
 ip address 172.16.1.1 255.255.255.0
 ip nat inside
interface Vlan180
 ip address 172.18.1.1 255.255.255.0
 ip nat inside
 --More--          ip virtual-reassembly
interface Vlan254
 description WAN connection for Voice router
 ip address 666.555.59.173 255.255.255.252
router bgp 65004
 no synchronization
 bgp log-neighbor-changes
 network 222.444.107.32 mask 255.255.255.224
 network 666.555.59.168 mask 255.255.255.252
 neighbor 222.444.117.17 remote-as 6372
 neighbor 222.444.117.17 description ourcompany XO EoC Primary Circuit
 neighbor 222.444.117.17 password asdfasdfasdf
 neighbor 222.444.117.17 update-source FastEthernet0/0
 neighbor 222.444.117.17 soft-reconfiguration inbound
 neighbor 222.444.117.17 weight 100
 neighbor 222.444.117.17 prefix-list ourcompany-Inbound in
 neighbor 222.444.117.17 prefix-list Outbound out
 neighbor 222.444.117.181 remote-as 6372
 neighbor 222.444.117.181 description ourcompany XO T1 Backup Circuit
 neighbor 222.444.117.181 password asdfasdfasdf
 neighbor 222.444.117.181 update-source Serial0/0/0
 neighbor 222.444.117.181 soft-reconfiguration inbound
 neighbor 222.444.117.181 prefix-list ourcompany-Inbound in
 neighbor 222.444.117.181 prefix-list Outbound out
 no auto-summary
ip forward-protocol nd
ip as-path access-list 50 permit ^6372_
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 198 interface FastEthernet0/0 overload
ip nat inside source list 199 interface Serial0/0/0 overload
ip nat inside source static tcp 10.100.0.251 80 interface FastEthernet0/0 8080
ip nat inside source static tcp 10.100.0.252 80 interface FastEthernet0/0 8081
ip prefix-list ourcompany-Inbound seq 5 permit 0.0.0.0/0
ip prefix-list Outbound seq 5 permit 222.444.107.32/27
access-list 23 permit 222.444.65.2
access-list 99 permit 666.555.17.2
access-list 99 permit 666.555.17.1
access-list 99 permit 222.444.65.2
access-list 99 permit 10.100.0.249
access-list 99 permit 222.444.84.197
access-list 198 permit ip 172.16.1.0 0.0.0.255 any
access-list 198 permit ip 172.18.1.0 0.0.0.255 any
access-list 199 remark Voice vlan NAT
access-list 199 permit ip 192.168.100.0 0.0.0.255 any
access-list 199 permit ip host 10.0.100.251 any
access-list 199 permit ip host 10.0.100.249 any
snmp-server community derp RO
snmp-server community derpy RW 99
snmp-server contact poop
snmp-server chassis-id company-eoc
route-map FilterFromourcompany permit 10
 match as-path 50
 set metric 200
control-plane
banner exec ^C
** This system restricted to uses approved by Kung Fu Enterprises **
^C
banner login ^C
 --More--         ^C
line con 0
 login local
line aux 0
line vty 0 4
 session-timeout 30
 access-class 99 in
 privilege level 15
 login local
 transport input telnet ssh
line vty 5 15
 access-class 99 in
 privilege level 15
 login local
scheduler allocate 20000 1000
ntp clock-period 17178418
ntp server 666.555.7.2
end
Philip D'Ath
What results do you get if you plug a notebook directly into the "hatteras" ?
Are you sure the hatteras is hard coded to 100/full, as opposed to auto/auto?  You will have big issues if only one end is hard coded.
I just found this thread because i was having the same issue. My outside interface was hard coded for speed and duplex. I took that off and fixed it instantly. Thanks
