STUN and UDP
dominiqueadam
I am trying to transport data with fast update rate over a WAN, via STUN (Serial Tuneling). Time accuracy being very important for this data, I would like to use UDP, instead of TCP (I prefer to lose packets, than to get outdated ones). Is there a possibility to have STUN use UDP instead of TCP (I have not found such possibilities in CISCO documentation)?
acampbell
I too have had a good search for UDP for STUN.
It looks like the TCP is set up as a virtual permanent path to give a reliable transport mechanism.
You could look at applying QOS over the WAN to give some priority to this type of traffic.
Alex
Regards, Alex. Please rate useful posts.
