Sub interface NAT problem
rasoftware
Level 6
Level 6
I have the following on an 1841.
PPPoE on Fast0/0 works fine and picks up ISP address.
I have assigned on the /29 address to fast0/1.2 and and created a LAN on fast0/1.1 using the native VLAN.
I can ping the /29 address from the internet and also ping the internal address from the LAN.
I added a NAT statement (inside and outside to each sub interface).
I cannot connect from the 192.168.199.0/24 network out via NAT.  Is this possible with subinterfaces?
vpdn enable
interface FastEthernet0/0
description PPPOE WAN
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.199.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 81.143.105.77 255.255.255.248
ip nat outside
interface Dialer1
ip address negotiated
no ip unreachables
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname ******
ppp chap password 0 *****
ip route 0.0.0.0 0.0.0.0 Dialer1 2
ip nat inside source list 10 interface FastEthernet0/1.2 overload
access-list 10 permit 192.168.199.0 0.0.0.255
dialer-list 1 protocol ip permit
I have the following:
I think this is what you want to do? Anything from inside - Client_Inside will be translated to 2.2.2.1 when I try to ping R2 which has a loopback of 1.1.1.1.
So all packets that are generated from the inside will be translated with a source address of 2.2.2.1. I have added a route of 2.2.2.1 back to R1 where the loopback exists.
here are the configs:
CLIENT_INSDIE#show run
Building configuration...
Current configuration : 827 bytes
version 12.4
hostname CLIENT_INSDIE
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip address dhcp
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
CLIENT_INSDIE#
CLIENT_INSDIE#show ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            20.0.0.101      YES DHCP   up                    up
FastEthernet0/1            unassigned      YES unset  administratively down down
R1#show run
*Mar  1 00:41:27.515: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1323 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 20.0.0.0 20.0.0.100
ip dhcp pool 1
   network 20.0.0.0 255.255.255.0
   default-router 20.0.0.1
no ip domain lookup
interface Loopback0
ip address 2.2.2.1 255.255.255.255
ip address 10.0.0.1 255.255.255.252
ip nat outside
duplex auto
speed auto
ip address 20.0.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 10.0.0.2
no ip http server
ip nat pool test 2.2.2.1 2.2.2.1 netmask 255.255.255.252
ip nat inside source list 100 pool test overload
access-list 100 permit ip 20.0.0.0 0.0.0.255 any
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.0.0.2 to network 0.0.0.0
     2.0.0.0/32 is subnetted, 1 subnets
C       2.2.2.1 is directly connected, Loopback0
     20.0.0.0/24 is subnetted, 1 subnets
C       20.0.0.0 is directly connected, FastEthernet0/1
     10.0.0.0/30 is subnetted, 1 subnets
C       10.0.0.0 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 10.0.0.2
R2#show run
Current configuration : 934 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback1
ip address 1.1.1.1 255.255.255.0
ip address 10.0.0.2 255.255.255.252
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip route 2.2.2.1 255.255.255.255 10.0.0.1
no ip http server
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Now I will ping 1.1.1.1 from client router:
CLIENT_INSDIE#ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/48/64 ms
R1#
*Mar  1 00:45:51.783: NAT*: s=20.0.0.101->2.2.2.1, d=1.1.1.1 [75]
*Mar  1 00:45:51.811: NAT*: s=1.1.1.1, d=2.2.2.1->20.0.0.101 [75]
*Mar  1 00:45:51.847: NAT*: s=20.0.0.101->2.2.2.1, d=1.1.1.1 [76]
*Mar  1 00:45:51.867: NAT*: s=1.1.1.1, d=2.2.2.1->20.0.0.101 [76]
*Mar  1 00:45:51.887: NAT*: s=20.0.0.101->2.2.2.1, d=1.1.1.1 [77]
*Mar  1 00:45:51.911: NAT*: s=1.1.1.1, d=2.2.2.1->20.0.0.101 [77]
*Mar  1 00:45:51.931: NAT*: s=20.0.0.101->2.2.2.1, d=1.1.1.1 [78]
*Mar  1 00:45:51.947: NAT*: s=1.1.1.1, d=2.2.2.1->20.0.0.101 [78]
*Mar  1 00:45:51.975: NAT*: s=20.0.0.101->2.2.2.1, d=1.1.1.1 [79]
*Mar  1 00:45:51.995: NAT*: s=1.1.1.1, d=2.2.2.1->20.0.0.101 [79]
R1#
*Mar  1 00:46:19.939: NAT: expiring 2.2.2.1 (20.0.0.101) icmp 14 (14)
R1#show ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
icmp 2.2.2.1:13        20.0.0.101:13      1.1.1.1:13         1.1.1.1:13
R2#
*Mar  1 00:45:24.731: IP: tableid=0, s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1 (Loopback1), routed via RIB
*Mar  1 00:45:24.735: IP: s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1, len 100, rcvd 4
*Mar  1 00:45:24.735: IP: tableid=0, s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), routed via FIB
*Mar  1 00:45:24.735: IP: s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), len 100, sending
*Mar  1 00:45:24.799: IP: tableid=0, s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1 (Loopback1), routed via RIB
*Mar  1 00:45:24.799: IP: s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1, len 100, rcvd 4
*Mar  1 00:45:24.799: IP: tableid=0, s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), routed via FIB
*Mar  1 00:45:24.799: IP: s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), len 100, sending
*Mar  1 00:45:24.855: IP: tableid=0, s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1 (Loopback1), routed via RIB
*Mar  1 00:45:24.855: IP: s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1, len 100, rcvd 4
*Mar  1 00:45:24.855: IP: tableid=0, s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), routed via FIB
*Mar  1 00:45:24.855: IP: s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), len 100, sending
*Mar  1 00:45:24.895: IP: tableid=0, s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1 (Loopback1), routed via RIB
*Mar  1 00:45:24.895: IP: s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1, len 100, rcvd 4
*Mar  1 00:45:24.895: IP: tableid=0, s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), routed via FIB
*Mar  1 00:45:24.895: IP: s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), len 100, sending
*Mar  1 00:45:24.939: IP: tableid=0, s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1 (Loopback1), routed via RIB
*Mar  1 00:45:24.939: IP: s=2.2.2.1 (FastEthernet0/0), d=1.1.1.1, len 100, rcvd 4
*Mar  1 00:45:24.939: IP: tableid=0, s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), routed via FIB
*Mar  1 00:45:24.939: IP: s=1.1.1.1 (local), d=2.2.2.1 (FastEthernet0/0), len 100, sending
So we are NATing the source to 2.2.2.1 which is not on the physical interface. You can also do this for sub interface.
Is this what you was trying to do?
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
11 Replies 11
Bilal Nawaz
Hello, It is possible.
I noticed that you have a default route here:
It may not be working because all the traffic being generated is heading towards Dialer1 interface i think?
What happens when you replace this with ip route 0.0.0.0 0.0.0.0 FastEthernet0/1.2?
or the ip route 0.0.0.0 0.0.0.0 x.x.x.x (your gateway on this network for your router - which is better)
hope this helps
i'v set as PPP assigned default route now but I still can't get out via NAT.
Show nat translations is empty.
Gateway of last resort is 81.139.64.1 to network 0.0.0.0
     81.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C       81.139.64.1/32 is directly connected, Dialer1
C       81.139.64.34/32 is directly connected, Dialer1
C       81.143.105.72/29 is directly connected, FastEthernet0/1.2
C    192.168.199.0/24 is directly connected, FastEthernet0/1.1
S*   0.0.0.0/0 [1/0] via 81.139.64.1
ocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES NVRAM  up                    up
FastEthernet0/1.1          192.168.199.1   YES NVRAM  up                    up
FastEthernet0/1.2          81.143.105.77   YES NVRAM  up                    up
ATM0/0/0                   unassigned      YES NVRAM  administratively down down
NVI0                       unassigned      NO  unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    up
Virtual-Access3            unassigned      YES unset  up                    up
Dialer1                    81.139.64.34    YES IPCP   up                    up
Do you want to route traffic out of dialer 1 interface? Or do you want to route out of the sub interface?
fast0/0 with PPP on dialer 1 is a dynamic IP assigned.  I have a subnet of /29 which I want to assign to the sub interface.  i want my traffic to appear to come from, this interface.
I've tried this now with NVI but no better.  What is going on here?
I see
A-ADSL#show ip nat nvi tran
Pro Source global      Source local       Destin  local      Destin  global
udp 81.143.105.77:137  192.168.199.3:137  192.168.199.255:137 192.168.199.255:13
7
So you want to route out of dialer 1 but make it seem like it came from FastEthernet0/1.2?
Hmm I'm not too sure... Won't we need a NAT address within the same range? How would the return traffic come back?
If you want to NAT out of dialer 1
Add the 'ip NAT outside' command on this interface. It won't NAT so that it seems like its come from fa0/1.2 though.
Do you want an asymmetric routing effect so the return traffic comes through another way?
I.e. goes out of dialer 1 and comes back to fa0/1.2?
If this is the case, NAT statement might be different, but I'll have to test it myself first.
rasoftware
Level 6
Level 6
Yes I can nat out of fe00. But why can I reach the public sub interface /29 from internet and even telnet on? Isp routes this via dynamic.
If you or the service provider are advertising out this prefix then it explains how you are able to ping and telnet etc..
The advertisement says, if you want to get to x.x.x.x the go to y.y.y.y being the next hop towards your sub interface.
How are you testing this? Have we achieved what we wanted to achieve?
No. What I would normally do is put a second router in. One dynamic ip on the outside and the gateway of the /29 on the inside then assign one of the /29 to this.
What I want to achieve is the same thing using a single router. I want the wan interface nearly to provide the routing to the isp and connection.
I am wondering if I use a loop back rather than a sub interface this would work? I would assign the /29 gateway to this...
I can reach any address in the /29 I assign to the sub interface so these addresses are definitely routable, what I can't do is nat out as one of them.
I need a static ip for VPN so I can't use the pppoe assigned ip.
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address dhcp
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
CLIENT_INSDIE#
R1#show run
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip dhcp pool 1
no ip domain lookup
interface Loopback0
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R1#show ip route
R2#show run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback1
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R1#
R1#
R2#
Hope this helps
I think all this is doing is translating the 192.168.199.3 address to 81.143.105.78 in my instance.
What I need is to be able to terminate an IPSEC on one of the /29 addresses
Normally
(ISP Dyaminc ---- 81.143.105.73 (GW) ---- (2nd device 81.143.105.74 - NAT and IPSEC Termination).
But i have now -
Dialier1 - IPCP
Loopback - 81.143.105.78
FE0/0 - 192.168.199.1
I don;t see it trying to make a nat translation in this configuration, but I can ping 81.143.105.78 from internet,
Perhaps it's not possible and I need the second device?
I did get this working of sorts using this - IP appeared to come from outside IP and I was able to terminate an IPSEC inbound but not outbound.  I'm not sure it possible to appear from interface without NAT so we opted for a firewall with a router in front.
This is a similar scenario to the Draytec 2nd routed IP and both seem to have issues initiating an IPSEC outbound in this configuration.
Thanks for the help.
