subslot 1/0 SM-X-4X1G-1X10G operational mode stuck in booting stage
Ramesh Dahiya
I have router ISR 4451 and tried to install NIM card but stuck in booting stage. Any suggestion will be highly appreciate !
Router#sh hw-module subslot 1/0 oir
Module Model Operational Status
subslot 1/0 SM-X-4X1G-1X10G booting
Router#sh version
Cisco IOS XE Software, Version 17.09.03a
Cisco IOS Software [Cupertino], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.9.3a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2023 by Cisco Systems, Inc.
Compiled Wed 29-Mar-23 01:13 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2023 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 16.12(2r)
Router uptime is 44 minutes
Uptime for this control processor is 45 minutes
System returned to ROM by PowerOn
System image file is "bootflash:isr4400-universalk9.17.09.03a.SPA.bin"
Last reload reason: PowerOn
Router#sh platform
Chassis type: ISR4451-X/K9
Slot Type State Insert time (ago)
0 ISR4451-X/K9 ok 00:45:40
0/0 ISR4451-X-4x1GE ok 00:44:41
1 ISR4451-X/K9 ok 00:45:40
1/0 SM-X-4X1G-1X10G booting 00:05:41
2 ISR4451-X/K9 ok 00:45:40
R0 ISR4451-X/K9 ok, active 00:45:40
F0 ISR4451-X/K9 ok, active 00:45:40
P0 PWR-4450-AC ok 00:45:08
P1 Unknown empty never
P2 ACS-4450-FANASSY ok 00:45:08
Slot CPLD Version Firmware Version
0 16092742 16.12(2r)
1 16092742 16.12(2r)
2 16092742 16.12(2r)
R0 16092742 16.12(2r)
F0 16092742 16.12(2r)
Router#
7 Replies 7
M02@rt37
Hello @Ramesh Dahiya,
Do you try to remove the NIM and re-insert it ?
Then check if the problem fixes itself.....
Best regards
Thanks for comment! We tried but still not working ..
johnlloyd_13
Level 9
Level 9
hi,
did you recently upgrade the IOS-XE?
can you boot to the other IOS-XE if there's a secondary code stored in flash?
Hi John,
We have tried with latest IOS and downgraded as well, still issue is same, Card in booting statge..
Hello Ramesh,
did you find a solution in the meantime?
I think I have the same issue on a 4451 (Cisco IOS XE Software, Version 17.03.04a).
Router7009#show hw-module subslot 1/0 oir
After around 15 minutes this is the output on my router
subslot 1/0 SM-X-4X1G-1X10G out of service(Authentication failed)
Router7009#show hw-module subslot 1/0 attribute
Slot 1 Bay 0 Board 0 Module[SM-X-4X1G-1X10G] spa_type 0xBC5 : Stopped or Removed
HI Clange..
Unfortunately, NIM card is not working in same router. Luckly, we tried in another router and same NIM card starts to work.
#sh hw-module subslot 2/0 oir
subslot 2/0 SM-X-4X1G-1X10G ok
#sh version
Cisco IOS XE Software, Version 17.04.01a
Cisco IOS Software [Bengaluru], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.4.1a, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Fri 18-Dec-20 05:04 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
software.
ROM: (c)
Mura_Bustan uptime is 12 hours, 50 minutes
Uptime for this control processor is 12 hours, 52 minutes
System image file is "bootflash:isr4400-universalk9.17.04.01a.SPA.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
AdvUCSuiteK9 None Smart License None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 appxk9 Smart License appxk9
uck9 None Smart License None
securityk9 securityk9 Smart License securityk9
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco ISR4451-X/K9 (2RU) processor with 1707020K/6147K bytes of memory.
Processor board ID FGL2617LXCX
Router operating mode: Autonomous
2 Virtual Ethernet interfaces
20 Gigabit Ethernet interfaces
1 Ten Gigabit Ethernet interface
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7081983K bytes of flash memory at bootflash:.
#sh platform
0 ISR4451-X/K9 ok 12:51:04
0/0 ISR4451-X-4x1GE ok 12:49:49
0/1 NIM-ES2-4 ok 12:49:49
0/2 NIM-ES2-4 ok 12:49:49
0/3 NIM-ES2-4 ok 12:49:49
1 ISR4451-X/K9 ok 12:51:04
2 ISR4451-X/K9 ok 12:51:04
2/0 SM-X-4X1G-1X10G ok 12:49:49
R0 ISR4451-X/K9 ok, active 12:51:04
F0 ISR4451-X/K9 ok, active 12:51:04
P0 PWR-4450-AC ok 12:50:34
P1 PWR-4450-AC ok 12:50:34
P2 ACS-4450-FANASSY ok 12:50:34
0 19042950 17.6.1
1 19042950 17.6.1
2 19042950 17.6.1
R0 19042950 17.6.1
F0 19042950 17.6.1
CLange
We had to replace the SM-X-4X1G-1X10G module as it was simply broken.
No issue with Cisco, received immediate replacement without sending the broken one back first.
