suggession on router
dhanikonda
Dear experts,
1. Do the above mentioned Routers series of 1841,2821 and 3825.Supports
data
along with voice ?.
2. If so then which type , whether FXO or FXS or both?
3. If they do support voice and in FXO mode then up to how many lines ?
4. Is Exchange necessary in case of a FXO?
In case the above mentioned Routers do not support FXO, FXS then kindly
suggest the router series that support the FXO and FXS .If it doesnt support why it wont support (reason)
Thanks&Regards
srini
shivlu jain
Level 5
Level 5
these series are ISR series and do suport voice as well as data. You can put 2 - 8 port fxo card in it if you are want to use the existing EPBX and want to bind with FXO thn it requires. Else no need for it.
http://www.ciscoexpo.gr/2006/downloads/0902/omega/hausner.pdf
regards
shivlu
