suggestion pref source using loopback IP
santox
Hi all,
I have a ASR1001 pppoe server with 2 wan interfaces. Routes manage by ibgp.
I would like to use loopback ip for in/out traffic and use it like pref source. Need this because Radius in this way will see only one IP
Try to use RMAP but I cant find right command
thank you and good work
ip radius source-interface loopback x << this this command
hi,
try this command but doesnt work. Radius still see connection using /30 ip and not via loopback.
try to disconnect users via Radius but dont do automatically because in Radius I only add loopback ip.
radius-server attribute 4 ip-address <<< this command not effect by NAT if there is NAT.
