Suitable license for IPSec in ISR4331
prashanma
Hi Team,
Do IPSec support for ISR 4331 - IPBase license ? Cisco Feature Navigator says it supports IPSec
IPSec is supported in the securityk9 package.
Your router has he universalk9 image preinstalled, which contains the ipbasek9 base package and the securityk9, uck9, and appxk9 technology packages. You have to activate it as right to use:
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/bm_isr_4400_sw_config_guide_chapter_0101.html#concept_9C59626376674562A33410817303BE08
Thank you George
