01-24-2019 08:19 PM - edited 03-05-2019 11:12 AM
What are the Cisco Access Level routers that supported MSDP and MBGP ?
Solved! Go to Solution.
01-24-2019 11:03 PM
ASR / ISR should able to support with latest stable Code. - again what model depends on design
you can verify below link ?:
https://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
01-24-2019 11:03 PM
01-24-2019 11:41 PM
01-25-2019 02:41 AM
The IP Base feature set includes advanced quality of service (QoS), rate limiting, access control lists (ACLs), and basic static and Routing Information Protocol (RIP) functions.
The IP Services image provides a richer set of enterprise-class features, which includes advanced hardware-based IP unicast and IP Multicast routing. Support for IPv6 Layer 3 switching in hardware is also available with the addition of the Advanced IP Services license to either the IP Base or the IP Services images. Both the IP base Image and the IP services image allow for Layer 3 and Layer 4 lookups for QoS and security.
Dynamic IP routing protocols (Open Shortest Path First (OSPF), BGPv4, Enhanced Interior Gateway Routing Protocol (EIGRP)) are available only on the IP services image.
For ISR License look below
01-25-2019 02:34 AM
