08-13-2013 06:14 AM - edited 03-04-2019 08:44 PM
Dears,
I have the below network in my work. the problem is that some IPs which are behind TMG (10.100.100.90 or 10.100.101.103 or 10.100.100.190) (suddenly) are not reachable to real machines (196.2.x.b or 196.2.x.a). the strange this is that the connectivity is restored once I add more specific route on the cisco router like this (ip route 10.100.100.90 255.255.255.255 196.2.x.c). i don't know what is the problem with these IPs although the same IPs are working before normally with only summarized route.
hope some one helps me in this issue.
regards,
08-13-2013 06:36 AM
Hi Ahmed,
You should look at what routes, other than the host routes, you have on 7204vxr to get to 10.100.101.20 and 10.100.101.90.
08-13-2013 07:24 AM
thanks Harold for your reply, but there is no route at all regard these IPs except the summarization route also i issued this command in cisco router
i'm ready to send you any log or debug you want to resolve this issue.
08-16-2013 09:16 AM
Hi Ahmed,
You mention that this worked before. What has changed since then? Can you telnet from the router to port 3389 (TCP port for RDP) on one of the workstations/servers behind the TMG to see if it works.
