Dynamic DNS behind NAT
Hello Community!,
i just configured my Cisco 1841 to works as modem/router with my Italian ISP that provide only dynamic IP to end users, for this reason, in user to use VPN etc, i need to configure a Dynamic DNS service on it.
The configuration is the following:
Cisco 1841 with WIC-1ADSL - FE0/0 configured with my private network IP and FE0/1 shutted down because i don't need it...
if i configure DDNS service on my router, it updates DynDNS or No-IP with my private Fe0/0 IP address; i followed a lot of guides that explain how to configure a DDNS service with dynamic IP without success.
Can i have more support by you?...
Thank you,
Riccardo
11 Replies 11
mfurnival
Level 4
Level 4
Hello, can you post your config please? You should have the ddns config on your dialer interface, not your f0/0 interface.
Thanks for you quick response, below my config:
Current configuration : 3077 bytes
version 12.4
service timestamps debug uptime
service password-encryption
hostname RA1-ITSOVI-1-1
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.200.36.1 10.200.36.10
ip dhcp pool RMSI_D_POOL
   network 10.200.36.0 255.255.255.0
   default-router 10.200.36.1
   dns-server 10.200.36.1 8.8.8.8 85.37.17.7
   domain-name RMSI.loc
ip dhcp pool S_NAS1
   host 10.200.36.7 255.255.255.0
   hardware-address 0090.a9ba.f4da
   client-name NAS1-RMSI-1-1
ip dhcp pool S_TimeCapsule
   host 10.200.36.9 255.255.255.0
   hardware-address 20c9.d013.7176
   client-name TC1-RMSI-1-1
ip dhcp pool S_NAS2
   host 10.200.36.8 255.255.255.0
   hardware-address 0090.a9bb.1c22
   client-name NAS2-RMSI-1-2
ip dhcp pool S_WS1
   host 10.200.36.2 255.255.255.0
   hardware-address 0025.6106.56c0
   client-name WS1-RMSI-1-1
ip dhcp pool S_RA2
   host 10.200.36.3 255.255.255.0
   hardware-address a493.4cc2.99c8
   domain-name gns.rmsi.loc
   client-name RA2-ITSOVI-1-2
ip ftp source-interface FastEthernet0/0
ip ftp username cisco
ip ftp password 7
ip domain list storage.rmsi.loc
ip domain list gns.rmsi.loc
ip domain name RMSI.loc
ip host RA1-ITSOVI-1-1 10.200.36.1
ip host NAS2-RMSI-1-2 10.200.36.8
ip host NAS1-RMSI-1-1 10.200.36.7
ip host TC-RMSI-1-1 10.200.36.9
ip host WS1-ITSOVI-1-1 10.200.36.2
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 10.200.36.1
ip ddns update method no-ip
HTTP
  add http://rikixx90:@dynupdate.no-ip.com/nic/update?hostname=rmsi.no-ip.biz&myip=
interval maximum 0 0 5 0
description LAN interface
ip address 10.200.36.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no ip mroute-cache
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
  pppoe-client dial-pool-number 1
interface Dialer0
ip ddns update hostname rmsi.no-ip.biz
ip ddns update no-ip
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname aliceadsl
ppp chap password 7 03055702050A20485D05
ip route 0.0.0.0 0.0.0.0 Dialer0
ip dns server
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 10.200.36.0 0.0.0.255
control-plane
banner motd ^Ctod ^
=================== "UNAUTHORIZED ACCESS IS STRICTLY PROHIBITED" ===================
All Unauthorized access will be logged and prosecuted to the fullest extent of the law^C
line con 0
exec-timeout 5 30
password 7
login
line aux 0
line vty 0 4
password 7
login
scheduler allocate 20000 1000
end
Looks OK to me. Can you do:
#ter mon
#debug ip ddns update
and then shut / no shut your dialer interface?
Here you go:
RA1-ITSOVI-1-1#term mon
RA1-ITSOVI-1-1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
RA1-ITSOVI-1-1(config)#int dialer0
RA1-ITSOVI-1-1(config-if)#shut
*Aug 16 12:31:28.875: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
00:16:32: Di0 DDR: dialer shutdown complete
*Aug 16 12:31:28.879: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
*Aug 16 12:31:29.891: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
*Aug 16 12:31:51.083: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*Aug 16 12:31:51.087: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Aug 16 12:31:52.695: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
*Aug 16 12:32:30.891: %LINK-5-CHANGED: Interface Dialer0, changed state to administratively down
RA1-ITSOVI-1-1(config-if)#no shut
*Aug 16 12:32:41.367: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
*Aug 16 12:32:41.371: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
*Aug 16 12:32:42.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
*Aug 16 12:32:43.363: %LINK-3-UPDOWN: Interface Dialer0, changed state to up
*Aug 16 12:33:03.587: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*Aug 16 12:33:03.591: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Aug 16 12:33:05.195: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
After shut/no shut operation, the IP address on No-IP address has been updated correctly....
So it is working then?
Did you turn the debug on? I don't see any DDNS debug in the output.
You're right, i'm sorry.. the debug loggins was turned off..
*Aug 16 13:12:58.483: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
00:01:53: Di0 DDR: dialer shutdown complete
00:01:53: DYNUPD: SWIF goingdown 'Dialer0'
00:01:53: DYNDNSUPD: Removing DNS mapping for rmsi.no-ip.biz <=> 79.20.166.102
00:01:53: HTTPDNS: Update remove called for rmsi.no-ip.biz <=> 79.20.166.102
*Aug 16 13:12:58.487: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
00:01:53: DYNUPD: SWIF goingdown 'Virtual-Access1'
*Aug 16 13:12:59.499: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
*Aug 16 13:13:01.903: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 10.200.36.11.
*Aug 16 13:13:02.903: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 10.200.36.12.
*Aug 16 13:13:20.703: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*Aug 16 13:13:20.707: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Aug 16 13:13:22.299: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
00:02:16: DYNUPD: SWIF comingup 'Virtual-Access1'
00:02:19: DYNDNSUPD: Adding DNS mapping for rmsi.no-ip.biz <=> 79.11.140.56
00:02:19: HTTPDNS: Update add called for rmsi.no-ip.biz <=> 79.11.140.56
00:02:19: HTTPDNSUPD: Session ID = 0x3
00:02:19: HTTPDNSUPD: URL = 'http://rikixx90:@dynupdate.no-ip.com/nic/update?hostname=rmsi.no-ip.biz&myip=
@dynupdate.no-ip.com/nic/update?hostname=rmsi.no-ip.biz&myip='
00:02:19: HTTPDNSUPD: Sending request
00:02:20: HTTPDNSUPD: Response for update rmsi.no-ip.biz <=> 79.11.140.56
00:02:20: HTTPDNSUPD: DATA START
good 79.11.140.56
00:02:20: HTTPDNSUPD: DATA END, Status is Response data recieved, successfully
00:02:20: HTTPDNSUPD: Call returned SUCCESS for update rmsi.no-ip.biz <=> 79.11.140.56
00:02:20: DYNDNSUPD: Another update completed (outstanding=0, total=0)
00:02:20: HTTPDNSUPD: Clearing all session 3 info
00:02:53: DYNUPD: SWIF goingdown 'Dialer0'
00:02:53: DYNDNSUPD: Removing DNS mapping for rmsi.no-ip.biz <=> 79.11.140.56
00:02:53: HTTPDNS: Update remove called for rmsi.no-ip.biz <=> 79.11.140.56
*Aug 16 13:14:00.483: %LINK-5-CHANGED: Interface Dialer0, changed state to administratively down
*Aug 16 13:15:23.583: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
00:04:18: DYNUPD: SWIF comingup 'Dialer0'
*Aug 16 13:15:23.587: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
00:04:18: DYNUPD: SWIF goingdown 'Virtual-Access1'
*Aug 16 13:15:24.591: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
*Aug 16 13:15:25.583: %LINK-3-UPDOWN: Interface Dialer0, changed state to up
00:04:20: DYNUPD: SWIF comingup 'Dialer0'
*Aug 16 13:15:45.915: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*Aug 16 13:15:45.919: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Aug 16 13:15:47.711: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
00:04:42: DYNUPD: SWIF comingup 'Virtual-Access1'
00:04:44: DYNDNSUPD: Adding DNS mapping for rmsi.no-ip.biz <=> 79.16.153.108
00:04:44: HTTPDNS: Update add called for rmsi.no-ip.biz <=> 79.16.153.108
00:04:44: HTTPDNSUPD: Session ID = 0x4
00:04:44: HTTPDNSUPD: URL = 'http://rikixx90:
00:04:44: HTTPDNSUPD: Sending request
00:04:54: HTTPDNSUPD: Response for update rmsi.no-ip.biz <=> 79.16.153.108
00:04:54: HTTPDNSUPD: DATA START
good 79.16.153.108
00:04:54: HTTPDNSUPD: DATA END, Status is Response data recieved, successfully
00:04:54: HTTPDNSUPD: Call returned SUCCESS for update rmsi.no-ip.biz <=> 79.16.153.108
00:04:54: DYNDNSUPD: Another update completed (outstanding=0, total=0)
00:04:54: HTTPDNSUPD: Clearing all session 4 info
i already checked on No-IP website and the new IP address is correctly updated, i tried many times and always it update it as well...
i would like to try also with DynDNS (my preferred service) and check if also with this DDNS system it works fine.
I have used dyndns on my 1841 in a similar setup and had no problems.
paolo bevilacqua
First of all, you should give a public IP address to the Cisco router, making it the router directly facing the internet.
If you cannot do that, remove "myip". from ddns configuration. The DDNS service will use the IP the request is received from.
Ok, thank you guys for your responsed, they solved my problems and dubs with DDNS on Cisco 1841.
let's try with DynDNS.
RIccardo
Please remember to rate useful posts clicking on the stars below.
just FYI and for support to this community, i just configured the DDNS update with my account DynDNS with the following config and it works very very good!.
ip ddns update method dyndns
HTTP
  add http://:@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
interval maximum 1 0 0 0
Thanks a lot for all the support received in this discussion!
Bye,
Riccardo Margiotta
