Summary CLNS routes
gemmafaura
I have a router with a lot of static clns routes, NET address for all these routes is only different in the system ID value, is it possible to redistribute only one summarized static clns route in router isis process?
Giuseppe Larosa
Hello Gemma,
I think you can create a summary address for the redistributed clns routes
static routes are redistributed by default in IS-IS and you should be able to filter
see
http://www.cisco.com/en/US/docs/ios/isoclns/configuration/guide/configure_iso_clns_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1070278
Hope to help
Giuseppe
