sup32 boot problem
Antonio_1_2
Can anyone please help me with this problem:
When I'm booting Catalyst6500 with sup32 It first goes to ROMMON mode:
if I issue "boot" command then it starts booting but with IOS version that doesn't exist
rommon 1 > set
BOOT=disk0:s3223-advipservicesk9_wan-mz.122-18.SXF9.bin
rommon 2 > dir disk0:
Initializing ATA monitor library...
Directory of disk0:
19752    51583012  -rw-     s3223-advipservicesk9_wan-mz.122-18.SXF9.bin
rommon 3 > boot
string is bootdisk:s3223-advipservicesk9_wan-mz.122-18.SXF7.bin
00:00:06: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
Then it starts ROMMON mode again but on RP:
rommon 1 > set
BOOTLDR=
?=0
rommon 2 > boot disk0:s3223-advipservicesk9_wan-mz.122-18.SXF9.bin
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "disk0:s3223-advipservicesk9_wan-mz.122-18.SXF9.bin"
rommon 3 > dir disk0:
bad device name (Device not supported)
It is the same thing if I boot on SP with
rommon 1> boot disk0:s3223-advipservicesk9_wan-mz.122-18.SXF9.bin
it ends up on RP rommon with the same problem
Thanks in advance.
A.
Antonio_1_2
I took another Catalyst 6500 and still have the same problem:
(I put on SP and RP boot variables that I have read from one of running 6500 with sup32 in my network - I issued show bootvar on RP and SP)
On SP rommon I have variables:
rommon 1 > set
PS1=rommon ! >
SLOTCACHE=cards;
ACL_DENY=0
BOOT=bootdisk:s3223-advipservicesk9_wan-mz.122-18.SXF7.bin
CONFIG_FILE=
BOOTLDR=
confreg=0x2102
BSI=
PF_REDUN_CRASH_COUNT=1
SUPW_1=1
CRASHINFO=crashinfo_FAILED
RET_2_RTS=09:06:46 UTC Tue Nov 15 2011
RET_2_RCALTS=1321348008
?=0
rommon 2 > dir bootdisk:
Directory of bootdisk:
2 50604580 -rw- s3223-advipservicesk9_wan-mz.122-18.SXF7.bin
I issue
rommon 3> boot
Self extracting the image... [OK]
Self decompressing the image : ################################################################################################### [OK]
MAC based EOBC installed
00:00:05: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:05: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
00:00:07: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:05: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:07: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
Cat6k-MSFC2A platform with 524288 Kbytes of main memory
rommon 1 > set
PS1=rommon ! >
CONFIG_FILE=
BOOTLDR=
confreg=0x2102
?=0
BOOT=sup-bootdisk:s3223-advipservicesk9_wan-mz.122-18.SXF7.bin
Then I issue:
rommon 2 > boot sup-bootdisk:s3223-advipservicesk9_wan-mz.122-18.SXF7.bin
00:03:08: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:03:08: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:03:08: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x42355684
  PC = 0x4040001c, SP = 0x415a6548, RA = 0x403fae14
  Cause Reg = 0x00001020, Status Reg = 0x34008002
rommon 2 >
Then again goes back to SP rommon.
This is the second 6500 that doen't want to boot. What am I doing wrong?
Please any help
A.
NUNO PIMENTA
Hello Antonio,
i'm facing this issue also. Did you ever manage to overcome it?
regards,
Nuno
Vinit Jain
Could you please try the following steps:
- Try to run ‘load_helper’ command, which initialize the bootloader to look for boot locations.
- After that ‘flash_init’ should initialize the flash.
- Once the flash is initialized, we should be able to set the boot variable through ‘boot disk0:<image>’.
- This should reset and reload the switch with the IOS image.
also, once you have set the boot variables, press "i" and enter. This should sync the boot variables.
Other things i would say is, before starting the above process, unset the variables.
Hope this helps.
Vinit
--Vinit
