Supengines, prp,rsp
ncnaveen_arasu
                   Dea team,
Could you please let us know what are the diffrences between Sup engines, PRP and RSP's.
Thanks in advance
Naveen
8 Replies 8
Raju Sekharan
Hi Naveen,
SUP720 is used by 6500,7600,..Switches. it has both Switching and Routing engine in it
PRP is the Routing engine for GSR
RSP is the Routing engine for 7500.
There is RSP720 which is used by 6500/7600 which has high CPU and memory than SUP720
Raju
HI Thanks for the reply.
One small clarification, Whre the IOS will store in these high end series routers and switch, wether in Supengine,PRP/RSP or a seperate flash will be available to store the IOS.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Where the IOS might be stored depends on the actual supervisor (and possibly how it's being used).  Most should have one or more internal flash memory banks on the supervisor card.  Some supervisor cards also provide an external memory slot (or slots), often one that supports compact flash cards.
For example a 6500 sup720b has an internal flash for the L2 engine, an internal flash for the L3 engine, and two CF card slots.  The internal L2 flash was used when running the sup720b in hybrid IOS mode, or using Catalyst IOS, but isn't used when running in native IOS mode.
To confuse things, on the 6500, the same flash bank might be accessible by more than one logical device name, and the one internal flash name might also have a different name depending whether the internal flash provides more than 512 MB (flash: or (bootflash: or. bootdisk:)).
You can also have an IOS image on different flash devices, and space permitting, different IOS images on the same flash.  You can specify multiply device:IOSName in the bootstring, where the system will boot into the first sucessful match.
Also, in devices that support multiple supervisors, the secondary device's flash banks will have device prefix names to distinguish them from the primary.  For example, on a 6500's active supervisor, it's first CF slot will be disk0: while the secondary's will be slavedisk0:.  Also confusing, this naming is based on hot vs. standby supervisor, not actual slot the supervisor is installed in.  I.e., if slot 5 is the active and slot 6 is the standby, the slot 6 memory devices have the slave prefix but if slot 6 becomes the active supervisor, then slot 5 gets the slave prefix.
HI Joseph, Thanks for the reply,
As per my understanding from your reply, Sup720b will have two CF card slots. Wether its an internal or we can use our external flash in that slots.
Hi Naveen,
You can use the external flash in any of the 2 external CF slots to boot the image
Raju
Disclaimer
Posting
Naveen, thank you for the thanks, but if you rated my reply "not helpful", sorry it wasn't.
Yes you can use the sup720b's two external slots, if they have CF cards installed, in addition to internal flash to store other files too (such as an IOS image).
HI Joseph, sorry it was happened by mistake !!!!
Disclaimer
Posting
Naveen, thanks so much for letting me know!  That's not a problem.  My concern was that you truly found my posting "not helpful".  Again, thanks for letting me know that wasn't the case.
